Wheel Bearing
Old May 20, 2011 | 10:30 PM
Originally Posted by wingman_214
OE parts fail for a reason
that sums it up right there....oe parts are designed to fail at a certain mileage...and therefore most people take their vehicles to the dealer to replace those "designed to fail at a certain mileage" parts with like parts that are "designed to fail at a certain mileage" and the cycle continues...my wifes 09 journey is a prime example...rotors, pads and tires....all used up before the 36k warranty expired...replace with the same factory stuff? I can expect another 30k or so...no thanks....since none of that was covered by the warranty (and they wanted close to $700 for a brake job and another $700 for the tires)...i said no thanks...went aftermarket, spent $250 for the brakes and $450 for the tires, AFTERMARKET, and I know they will last a sh!tload longer than 30k....
Old May 21, 2011 | 06:24 AM
cramerica's Avatar
cramerica
I replaced one at 37,000 mi and the other is factory original at 67K without problems. The OEM ones have a high failure rate.
Old May 21, 2011 | 05:01 PM
superdak05's Avatar
superdak05
my dakota went 100,000 miles before i needed them changed out, only one went but decided to do both, have the non abs in frt, got them at napa, 3 yr 36000 mile warrenty,cant beat that, 300.00 for both
Old May 23, 2011 | 06:55 AM
dodgedkota08's Avatar
dodgedkota08
The guys at the shop said it was noisy but not loose, how many more miles do you think I could get out of it?
Old May 23, 2011 | 08:05 AM
wingman_214's Avatar
wingman_214
Noisy means the bearings are running with out grease. Its won't be very long untilled they overheat and fail especially if you use the highway. The bad bearing may disintegrate, cause alignment problems and waste gas.
Old May 23, 2011 | 08:33 AM
Talking
I'd just go ahead and replace it. It's not that bad of a job. I had to remove mine when I replaced my CV axle, aside from the axle nut, there are 4 bolts that hold the hub on. Thats it.
Old May 23, 2011 | 10:17 AM
Brand's Avatar
Brand
That's always puzzled me: You can't service JUST the front wheel bearings themselves on these Dakotas? Not without replacing the whole front HUB? How does that work?
$300 just for PARTS sounds awfully expensive for a front wheel bearing job. Maybe I'm showing my age here.
Old May 23, 2011 | 10:27 AM
Non servicable.
http://www.oreillyauto.com/site/c/de...0055&ppt=C0337
Old May 23, 2011 | 10:28 AM
wingman_214
Most newer vehicles come with sealed hubs now days. Its really very easy to swap them out. Just remove the wheel, then remove the cv shaft nut if you have 4x4, remove the 3 mounting bolts. Reverse to install, should take less than a 6 pack to do both sides.
Old May 23, 2011 | 10:41 AM
I like to stretch mine out....6 pack for each side....
