Need help getting rid of smoke smell....
Old May 21, 2011 | 01:12 PM
fingers588's Avatar
fingers588
Default Need help getting rid of smoke smell....
Hey all,
My Dak is a 2005 with 90k and when i purchased it from the dealer, there was no smoke smell on the test drive although there was evidence of the previous owner being a smoker. A small burn on the headliner, small burn on the driver's side door panel and a little ash under the driver's seat. I purchased it in the fall and over the winter, whenever i turned on the heat or defroster, you can smell a small trace of smoke. Now that its starting to warm up, the smell is more pronounced to the point my clothes are starting to smell like I was at a bar. Anyone got any suggestions to get rid of the smell? I dont want to febreeze the crap out of the interior because thats just masking the smell. I need to get rid of it completely!! PLEASE HELP FOLKS!!
Old May 21, 2011 | 01:27 PM
Mine did too. I have leather seats though. I have a carpet cleaner and used that to clean the carpets and headliner. I also have a constant supply of little tree air fresheners. Over time the smell is fading.
Old May 21, 2011 | 01:51 PM
cheeseburger's Avatar
cheeseburger
use airwick or febreze in the duct work for the ac? little trees?
Old May 21, 2011 | 02:19 PM
MitsuRaider's Avatar
MitsuRaider
Wink
Ha ha, I think he means those pine shaped air fresheners.
I too use "little trees" to scent my car
Old May 21, 2011 | 03:09 PM
Corks's Avatar
Corks
The car dealer i was at used auto vaccine. its pretty toxic and you have to follow the directions exactly in order to not get sick but as long as you follow the directions it takes the smell out of the whole car and system.
Old May 21, 2011 | 03:21 PM
Brand's Avatar
Brand
Google is very fruitful on this topic. Lots of suggestions, from Dial soap or Bounce dryer sheets under the seats, to ozone products, to "Atmosclear", to tupperware containers of coffee grounds left open in the car overnight.
After shampooing and deodorizing the carpets, upholstery and headliner, of course. And scrubbing down all the glass and plastics. AC and heater ducts are the hardest, I think.
http://removingsmoke.com/car.html
Old May 21, 2011 | 03:22 PM
damyankee84's Avatar
damyankee84
Well you can buy an air duct cleaner/deoderizer, I think it's a spray. For the rest of the interior, like Corks said, alot of dealers have something they put in the car. The ones I have seen do it, it's like a fogger that fills the car full of a smokey fog then the close the door and let it do its work. Or just go to a good detail shop and see if they do it.
Old May 21, 2011 | 04:04 PM
exactly. $2.99 for 6 of them at wallyworld...they last about 2 weeks. i prefer the "new car" scent. Black ice is good too.
Old May 21, 2011 | 04:24 PM
BMSJaX's Avatar
BMSJaX
I had the same problem in mine. I used Fabreeze(which by the way does not cover smells but helps remove them) I also went through a billion little tree fresheners and it faded over time. Now it hardly smells at all. The Ford dealer we use for work suggested putting a gallon of vinegar in a 5 gal bucket and leaving it in the truck over night. We did it in one of our work vans and it worked pretty good.
Old May 21, 2011 | 07:04 PM
sullysdetailing's Avatar
sullysdetailing
Use this stuff
http://www.autogeek.net/smoke-odor-eliminator.html
http://www.autogeek.net/3pack-odor-bomb.html
