Dakota 2010 4wd 2" lift kit
Old May 22, 2011 | 10:02 PM
mauricio4x4's Avatar
mauricio4x4
Exclamation Dakota 2010 4wd 2" lift kit
Hi everyone,
Im new in the forum but I have read some postsabout this problem of lifting the dakotas.
I need to lift 2" in the front for 32" tires, and replace the OE shocks by a firm ones. I found Bilstein and Rancho models that I looks very well and I found forums showing them installed on RAMs.
How could be posible that Bilstein 5100 ride height adjustable and Rancho Quicklift shocks are not manufactered for our Dakotas??
Does anyone know how diferent are the RAM 1500 OE strut and the dakota strut?? Bilsteins and Rancho exist for RAMs.
In case that I finally cant lift with Bilsteins or Ranchos, do this shocks exists just to replace the original strut?? this could be a 2nd option, replace the original strut with a better shock and use a spacer to level the truck....
I think this is a problem that must be taken by all of us who wants to level our trucks and explain it to a manufacturer... simple as that.
well, I´ll apreciatte a lot your help.
thanks
Old May 23, 2011 | 06:19 AM
Backwoods18's Avatar
Backwoods18
Welcome to DF. Ok, question 1: If you want to lift the front you can purchase a strut spacer. I think Daystar makes a 2" kit. Since you are replacing the struts, the stiffest strut you can buy are ranchos.
Question 2: The ram struts are different, from what I can tell. You are not going to be able to level or lift the front with just struts alone. There are no self leveling struts/springs available.
Your only option is a strut spacer as you mentioned. Hope this helps
Old May 23, 2011 | 07:31 AM
Rancho or Monroe struts. Max. 2.5" spacer with 4x4. Thats about your only choices.
Old May 23, 2011 | 08:55 AM
dakota_raven's Avatar
dakota_raven
Old May 23, 2011 | 03:32 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Even 2.5" is questionable for me Don't get me wrong, after seeing a members truck with it on there...I wanted it. I know a select few have done it, but I'm still wondering how it effects longevity of the critical components.
Old May 23, 2011 | 03:57 PM
I agree, 2.5" is pushing it. I'm going with 2". But there are a couple with 2.5" who don't have issues...yet......
Old May 23, 2011 | 04:36 PM
cheeseburger's Avatar
cheeseburger
fingers crossed but so far so awesome...
Old May 23, 2011 | 05:30 PM
Dakkkota's Avatar
Dakkkota
not bad...2 years
Old May 23, 2011 | 06:57 PM
mauricio4x4
thanks to all answers!!!so.... rancho 5000 front struts + strut spacer seems to be the solution to get 2" lift and a better or firmer ride.does anyone know if exist rancho 9000 front stuts for dakota???any idea about the part numbers for 5000 and 9000 if they exists??which store is good?
Old May 23, 2011 | 07:18 PM
mauricio4x4
also, keep the CV joints, tie rod, upper A arm and all things factory OE??
just the rancho + 2" spacer??
which spacer? the poliuretane or metalic ones? any brand is better?
