check engine p0344???
Old May 24, 2011 | 05:48 PM
Dakkkota's Avatar
Dakkkota
Default check engine p0344???
what it it?? should i change the cam sensor? my truck is still on powertrain warranty.
any idea of troubleshoting tricks?
Old May 25, 2011 | 06:49 AM
Backwoods18's Avatar
Backwoods18
You are right with the Cam shaft. The code is "Cam Shaft Sensor Intermittent". Could possibly be your sensor is going bad.
Old May 25, 2011 | 07:34 AM
wingman_214's Avatar
wingman_214
Do you have a intermitten starting issues? Does the engine die randomly? If so the sensor is going bad. Its simple to change, one bolt and a connector. Should run about $30 or so usd.
Edit:
Borg Warner CSS635. We sell it for $24.99. Its mounted on the passengers side towards the front, looks like its on the under side of the valve cover.
Old May 25, 2011 | 05:27 PM
Deer Hunter's Avatar
Deer Hunter
if it's easy to swap out it's probably worth the $25 to not lose your truck for a whole day to the dealer.
Old May 25, 2011 | 08:07 PM
Dakkkota's Avatar
Dakkkota
should i pick a mopar or a jobber borg wargner etc???
Old May 25, 2011 | 11:18 PM
hendrixx324's Avatar
hendrixx324
i got the after market cam position sensor
