front diff noise?
Old Jun 1, 2011 | 01:39 PM
mxkawi900's Avatar
mxkawi900
mine does this too only in 4wd though and i looked underneath my truck and found out that my front diff. passenger side mounting braket busted clean off. whats that about?
Old Jun 7, 2011 | 03:15 PM
thunder98110's Avatar
thunder98110
turning left noise goes away, turning right its much worse. highway speeds its not really there.10-50mph is bad. steering gear or something?
my buddy in the 2g section still thinks its the wheel bearing although when i tested it the tire wont budge.
Old Jun 8, 2011 | 10:27 AM
GrnDak01's Avatar
GrnDak01
He may be right. When my right one went bad it wasn't making a lot of noise yet. In fact I wasn't sure which one it was. I don't remember being able to budge it myself. It also would go away if I turned one way and get worse if I turned it the other way.
I know the feeling, the truck runs great for a while and I'm really happy with it then something happens and I'm bummed out. I keep having to tell myself "It's a ten+ year old truck you have to drive everyday so things will eventually crap out". So don't get too down and out, you'll get to the bottom of it.
Old Jun 8, 2011 | 01:05 PM
hendrixx324's Avatar
hendrixx324
That right there makes me think its wheel bearings. have you ever replaced wheel bearings on your truck.
Old Jun 8, 2011 | 01:26 PM
any vibrations or just sounds?
Old Jun 8, 2011 | 01:36 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
That def sounds like a wheel bearing. If it wobbles or wiggles its very serious. You are in the beginning stages so the wiggle shouldnt be very noticeable if at all.
Old Jun 8, 2011 | 04:04 PM
thunder98110
it drives normal, no issues with steering, just the noise and vibration in the foot well.
