How big is YOUR throttle?
I figured this applies in the 3G section because my Dak hauls the race car. Here's the latest for the Talon:
Nissan Q45 throttle body and Magnus sheet metal intake manifold. The welded sections on the runners were to close up the direct port nitrous nozzle taps. Obviously, I need more tig practice. But its a race car, who cares?
Here's the comparison of the stock 60mm tb vs. the Q45 90mm tb.
Holy crap, that's an enourmous throttlebody. I bet that thing wont hardly idle right.
Why didn't you just plug the ports so you can use them at a later date?
Lol...maybe you should weld some more fins on the turbo.
Trending Topics
I don't run nitrous, so there was no need to plug the ports. With the new turbo, I'm going to have my target boost set at 30psi. Welding is the better option here. Plus, the previous owner stripped the threads. I suppose I could weld some fins to the turbine wheel, increase the spool time and top end flow...lol.
Eric, my IC piping is 3", post intercooler. I have an AEM standalone now, so tunability will be more precise.
