How is this plug burning?
Old Jun 6, 2011 | 10:25 PM
Dakota2005sp's Avatar
Dakota2005sp
Default How is this plug burning?
See sig for truck info
They are original and pretty worn. I put the Bosch coppers in.
http://img534.imageshack.us/i/imageverj.jpg/
Thanks
Old Jun 6, 2011 | 10:29 PM
Eimer123's Avatar
Eimer123
Looks pretty normal. Contact worn down. Nice white ceramic. I would say nothing is wrong, Unless the rest looked completely different, or this happened in very low miles.
Old Jun 6, 2011 | 10:32 PM
wingman_214's Avatar
wingman_214
ash building on the ground strap indicates too much fuel injector cleaner is being used.
Does it look like it has glitter sprinkled on it?
Old Jun 6, 2011 | 10:43 PM
Dakota2005sp
They all look the exactly the same.
Yes a yellowish glitter color kinda like little spots raised up a bit.
Thanks for the fast replies.
Old Jun 6, 2011 | 10:49 PM
Eimer123's Avatar
Eimer123
I think most of the crap on the strap is due to how worn down the plug got. I would just check one of the new plugs every 3000 miles (which should be done anyways).
Old Jun 6, 2011 | 10:51 PM
wingman_214
Do you do a lot of highway/towing and hauling?
Seems your plug is too hot. it should be tan in color and no sparkles. similar to this.
Old Jun 6, 2011 | 10:52 PM
Dakota2005sp
Ok thanks.
Do you think gas millage will improve a bit since they were so worn and having a big gap?
I gapped the new ones at a tight 40
Old Jun 7, 2011 | 01:11 PM
Jetster220's Avatar
Jetster220
I have a question on the plugs guys, at how many miles on the truck should you replace the original plugs?
Old Jun 7, 2011 | 02:39 PM
wingman_214
Copper plugs usually go at 25-35k. Platinums 50-75k. Iridium 75-100k. Not withstanding any other failures.
Old Jun 7, 2011 | 09:47 PM
Jetster220's Avatar
Jetster220
What kind of plugs are in the 3.7L stock?
