After Market Fog/Driving Lights
More than likely this has been covered in the past however, have not been able to find the answer.
Was going through my owners manual and looking over the power distro center and noticed that there there is 40 amp fuse for the parking lights, seems to be like 10 amps per light due to some other things I saw in the layout. Anyhow, would running a power wire to after market lights to the distro box and into the parking lights cause any problems? I really do not want to run a seperate toggle switch for the lights and was hoping that when the parking lights were in the on position, that would power up the driving/fog lights
If the above info cannot be done, any ideas on after market set ups?
Thanks,
Birk
Thanks,
Birk
on
I would install a separate relay for the added lights for power, separate ground, etc. but instead of running a switch, run off the pin on the relay you would run to a switch and tap into the relay or wire running to the switch for your existing lights. Thisaway if you have an issue with the lights you add, they will not take out your driving lights.
I did this with my pair of 130 watt lights only I ran the relay to the fog light relay. I seldom used the fogs, so my factory fog light switch now turns on both the fogs and the off-road lights, but other than the line to the fog switch relay pin, the off-road lights are separate, have their own power wiring, fuse, relay and ground, so if I blow them, I don't take out the fogs.
Also, if you happen to have the over-head console with the HomeLink option, I have a REALLY cool setup to use the unused buttons for that that I run in my Grand Cherokee...
