HHR fan installed.. is horribly vibrating!
Old Jun 25, 2011 | 07:32 PM
Hammond_Egger's Avatar
Hammond_Egger
Default HHR fan installed.. is horribly vibrating!
OK, I finally got my HHR fan installed, and it seems to be functioning fine...minus the vibrating.
It looks like the fan is out of balance (even has a weight on it), you really feel it on fan start up, but it is there all the time.
I have ordered another, will have it in 3 days (hopefully).
Anyone else have this problem?
Old Jun 25, 2011 | 08:02 PM
wingman_214's Avatar
wingman_214
Mine has no vibration at all. It also had 2 or 3 weights. What brand did you buy?
Old Jun 25, 2011 | 08:42 PM
Eimer123's Avatar
Eimer123
No weights on mine, spins perfect.
Old Jun 25, 2011 | 11:17 PM
Hammond_Egger
I bought a Dorman....Will see how the next one works out.
Thanks!
Old Jun 25, 2011 | 11:30 PM
how hard was it to install? notice any difference (besides the vibration)....??
Old Jun 25, 2011 | 11:53 PM
Jetster220's Avatar
Jetster220
Mine has a minor vibration I can feel in the steering wheel just a bit. It has a weight on it for balance but guess they didnt do the best job.
Old Jun 26, 2011 | 08:41 AM
Hammond_Egger
Kent, I have only driven it around for a test ride...stay tuned!
Old Jun 26, 2011 | 09:22 AM
Eimer123's Avatar
Eimer123
Install is not bad. Just need to have general electrical skills.
I had to remove mine because the CAI took up the room where I had my Spal controller mounted.
When I reinstall it soon I will be doing a perfect write up for everyone. Just need to find a new location for the controller. Probably gonna be in the cab.
As far as noticing a difference. I noticed a slight increase in power. But the largest change was the engine lag.
Old Jun 26, 2011 | 03:14 PM
Hammond_Egger
Oh, I have the PERFECT location for you...on the front of the battery tray!
I will have some pics for you tomorrow...
Old Jun 28, 2011 | 03:44 PM
Hammond_Egger
OK, new fan is installed, BIG difference...smooth now! I also changed the waterpump, both hoses, threw in a 180deg thermostat and replaced the belt and changed the antifreeze (best I could do was 2 gallons without flushing it).
Here are some pics of the install. I used bailer track (Tractor Supply) to fill in the gaps on the side of the shroud. I coated the whole assembly (minus the fan/motor) with bedliner in a can. I also re-purposed the nice water proof connector to have a disconnect for the AC and Temp leads (All connections were soldered/crimped/shrinked with marine grade tubing).
Eimer, take a peek at where I mounted the spal controller. I had to flip one of the horns to fit it, but I think it the best spot. I used flat carriage bolts (1/4 inch..WAY overkill, but I had them).
Special thanks to all who did this before me, you made it easy!
Kent, Adding just the fan did help with lag.The fan with the 180 thermo made a bigger difference, IMHO. Next stop, HO cams
