Rear end sag? (or instant leveling kit...)
Old Jul 2, 2011 | 08:29 PM
JR6424's Avatar
JR6424
Default Rear end sag? (or instant leveling kit...)
Well I just had my bed Rhino lined (~50lbs) and and a Leer XL cap installed (~250lbs) and now I no longer need to install a leveling kit. I wish I had before and after kits but my truck used to ride *** high like they all do and I was planning on installing a leveling kit but now with the bed liner and cap it looks level or maybe even a little nose high with a full tank of gas and a few random boxes in the back, I'm going to measure ride height soon to be sure. So... any recomendations for bringing her back up to normal? I've heard of add-a-leaf, helper springs, air bags and "blocks", anyone care to debate the differences and pros/cons of each?
Thanks,
JR
Old Jul 2, 2011 | 08:53 PM
Eimer123's Avatar
Eimer123
Simple and easiest would to be just add a 1", 1-1/2", or 2" rear block. I will be adding a 2" rear block tomorrow morning. You will need new U-joints also.
Add a leaf will stiffen the rear end for the worse, but will increase load capacity a little.
Helper springs, air bags, monroe coil rear shock, wont bring up the rear end, just help with sag under load.
Old Jul 2, 2011 | 11:10 PM
dsimm87's Avatar
dsimm87
Well, his rear end is under a load now (hence the sag). If you're gonna do any towing I'd go for the monroe coil shock. Our shocks are bad to begin with. Go ahead and replace it with that. It should compensate for the extra load and raise it back to normal & you'll be happier down the road I when you do tow something.
Someone can back me up on this, since I don't have those shocks (yet) but I've done some research and thats just what I decided to do for my truck.
Old Jul 3, 2011 | 04:23 PM
KS Cowboy's Avatar
KS Cowboy
2006 ram 2500 rear leafsprings will fix it, but again as mentioned above about the rear add-a-leafs, it will be a rough ride, but you'll be able to haul a s*** ton of things.
Old Jul 3, 2011 | 06:01 PM
wingman_214's Avatar
wingman_214
+1 for the monroe sensatrac load leveling shocks.
Old Jul 3, 2011 | 11:02 PM
JR6424's Avatar
JR6424
U-joints or U-bolts?
I think I'm leaning toward the Monroe coil shocks, at 80K my shocks are overdue for replacing anyway and hopefully the new shocks will bring the rear end back up to normal height. I've been thinking about a small lift down the road so 2" blocks in the rear and a 1.5" leveling kit up front might be on the menu later on.
Thanks for the help!
Old Jul 4, 2011 | 12:52 AM
marcsnyder05's Avatar
marcsnyder05
I vote for the shocks I just put the monroe reflexs on my truck and with about 500 pounds in the bed it's sitting at stock height
Old Jul 4, 2011 | 07:23 AM
Backwoods18's Avatar
Backwoods18
Yes sir. Thats is what I have in mine. I can hook my camper to up (about 2300#) and there is only a 1/2 inch of sag. The ride actually isn't too rough. It seems a little more bumpy but it doesn't jar you in side the cab as one would think.
Old Jul 4, 2011 | 03:00 PM
Blown287's Avatar
Blown287
How about a leaf spring stabilizer?
Old Jul 5, 2011 | 12:53 PM
Altair's Avatar
Altair
Dak attack!
I wouldn't have expected that much sag with that little weight. I have the rear leveling kit on mine, rhino-lined bed, and when moving recently with a bunch of furniture in the back the rear never squatted visibly. For all I know I may not have had as much weight as I thought in there and that squatting is normal but you may want to glance at your rear leafs and make sure nothing is broken. It never hurts to check and it's easy to just stick your head under there and look.
