07 3.7 Electrical Problem???
Ok my truck has 95,000 miles. Never had a problem with it until today. I drove to work and then to lunch. Left work and my truck wouldnt start. However, the gauges moved for a second when i turned the key, then nothing. I did notice two little lights beeping on the gauge cluster(upper right hand corner). So Im thinking dead battery, I get someone to jump me off. Well it doesnt start up first try, it doesn't do anything except the rpm and speedo gauges move. Finally after turning the key 5 or 6 times it cranks. But now my ac light is blinking and check engine light is on, also the mileage light is blinking. Anyone have a clue. (Not sure if this could cause this but it was storming really bad today). This is just so random. I'm pissed....
ok I have an update. the truck will not start without jumping it off. But when you do get it running, the lights flicker and the a/c light blinks on and off even with the unit turn off. Could this be an alternator. Although, I did disconnect the battery and the truck still continued to run. I always thought once alternators go bad it either works or doesn't. ( do they slowly die?)
Removing the cables to check your alternator may have been true for your grampa but most modern vehicles will automaticly shut down to prevent damage to the circuts.
I would check your battery, if it has a crappy cell and isn't consistantly delivering 12.6 volts yhe ecm wont " think" correctly. Check the negative cable as well if it isn't providing good ground it will cause the same issues.
Trending Topics
I'm assuming the battery is from the factory. I haven't changed it in my two years of owning it. Its an 07 truck. I will be taking it to advanced today. Thanks for the responses.
