HELP! may buy a dakota...
Old Aug 13, 2011 | 03:50 PM
farrama's Avatar
farrama
Default HELP! may buy a dakota...
Whats up guys, I am in the market to buy a new pick up truck and i need some help on the dakota. I love the look of this truck and its just the right size.
My questions reside around performance. I have owned several "fast" mustangs and currently drive a 14 second GTI. (not fast) I would like to purchase a black, ex cab 2x4 4.7 big horn dakota and turn it into a street truck. slight drop, intake, pipes tune.. nothing crazy.
My question is what are the factory performance figures on a 2x4 4.7?
I have searched the web high and low and there is a very small amount of info around the 2008 plus performance.
from what i can tell a 4x4 quad cab hits 60 in around 7 seconds and 15s in the 1/4 around 88-90mph. Has anyone ran a 2x4 ex cab at the track. logic would tell me this should be a mid 14 second truck right out of the box.
OOOOR... would i just be better off buying the new ram express?
thanks for the help in advance. also, are there lowering kits avalible for 3rd gens?
Old Aug 13, 2011 | 04:10 PM
EliteTempleton's Avatar
EliteTempleton
Welcome to DF!
I'm more of a 2 Track Truck guy but if you want a performance street truck you want to get one of the 4.7 High Output motors to start with.
Only stock performance data I know of http://en.wikipedia.org/wiki/Dodge_D...ird_generation
Only thing I know about lowering them (I'm looking into the TM front end lift myself...) https://dodgeforum.com/forum/3rd-gen...nt-ban-me.html
Old Aug 13, 2011 | 04:26 PM
farrama's Avatar
farrama
thanks, for the responce. i def want the 4.7HO, seems like this power to weight ratio should make it a beast.
Old Aug 13, 2011 | 09:44 PM
wingman_214's Avatar
wingman_214
08+ is already h.o., it makes around 300hp stock. With a tuner, intake, exaust uts an easy 350hp. The problem is the weight, at around 6k she's a beast.
Old Aug 13, 2011 | 09:52 PM
cheeseburger's Avatar
cheeseburger
before you make your decision you may want to price all the stuff you want to buy for it. there isnt much in the way of aftermarket support for a 3rd gen.
Old Aug 13, 2011 | 10:07 PM
popsnbeer's Avatar
popsnbeer
If you don't need the ext cab of the dak, the express w/ hemi will have far more (and less expensive) options. I believe it runs low 14s right out of the box too.
I know the 08+ have 300hp out the gate, but the torque management is horrible (this is what i hear anyways. I own an 06 4.7ho). After a tuner, exhaust, and cai i hear there are nominal gains.
Hope that helps.
Old Aug 14, 2011 | 12:32 PM
silverbullit's Avatar
silverbullit
More aftermarket for the hemi so if you want unlimited tuning options go with a ram hemi.
Old Aug 14, 2011 | 12:44 PM
JimBio's Avatar
JimBio
After owning a 400hp Dakota R/T, SRT-4 and Camaro Z-28 I was in the boat for a quick 4 door truck (have kids now) and the Dakota was really the only choice for a quick truck that doesn't get 13 mpg. After adding the programmer and a few bolt ons (throttle body, cold air intake, exhaust) it fills my need for speed with the exception of "off the line" power. I believe some 4:10 gears or higher would fix that. Once your rolling it's a beast, this fall I would like to take mine to Houston Raceway Park and see how the numbers stack up. Probably would expect a high 14 second time which is fine for a truck that gets 17-22 mpg and can haul some people. I would prefer a high 12 second truck but already been there and done that, so I'm good.
Old Aug 25, 2011 | 08:49 AM
Racinartist's Avatar
Racinartist
Cool
My 08 is a 4WD (AWD actually), TRX4, quad cab, V8 and curb weight is listed at 4782, according to Dodge. As far as I know the only model that's heavier is the Laramie by like 100-200lbs.
I've seen the 6000lb # on some websites too, but they're obviously wrong.
