Remote door lock range
Old Aug 14, 2011 | 06:27 PM
DakotaAgain?'s Avatar
DakotaAgain?
Default Remote door lock range
I practically have to be only feet away from the truck for my remote door lock to work. It is also very directional. I have to approach from the rear left. Is it a low battery or the range isn't just that good?
Old Aug 14, 2011 | 07:38 PM
Corks's Avatar
Corks
I get better range from different sides of the truck but for most of the time I can usually get it to lock/unlock from 20 or more yards away
Old Aug 14, 2011 | 07:46 PM
BrandNew's Avatar
BrandNew
That is why I got a viper alarm. I have a 1 mile range with that.
Old Aug 14, 2011 | 08:03 PM
marcsnyder05's Avatar
marcsnyder05
I would say it's the battery in your remote. Before you change it make sure that you have a spare key, because once you remove the battery the key loses it's programming. So once you put the new battery in you'll have to reprogram the key. The directions for that is in the owners manual.
Old Aug 14, 2011 | 09:27 PM
seriously?? what a pia!
Old Aug 14, 2011 | 11:15 PM
Hammond_Egger's Avatar
Hammond_Egger
Here is a trick I did not believe until I tried it..and I am quite serious:
Place the remote under your chin, pointing upward, then hit a button. Your range will be better than double.
I lost a $20 bet on this one...it works!
On another note...I have changed several batteries on my Dak remote as well as my Grand Caravan..never needed to reprogram it.
Old Aug 14, 2011 | 11:20 PM
DakotaAgain?
Yeah, I have changed the battery once with no issues. Even when new, the range was not impressive.
Old Aug 15, 2011 | 02:26 AM
marcsnyder05
Oh I thought I read in the owners manual that if you change the battery you have to reprogram it
Old Aug 15, 2011 | 07:11 AM
Eimer123's Avatar
Eimer123
If you leave the battery out for a long period of time, or let the battery stay dead for a long period of time, the key will lose its internal change and programming goes by by like my keys. My dealership said they would reprogram mine for free, but I have been so used to not having the fob working for 4 years its not on my priority list.
Old Aug 15, 2011 | 08:25 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Sounds like a dieing battery, I get some awesoem range out of my. I would almost bet 500 ft. I have tried the theory Hammond mentioned... its bizarre and works... LOL
