several things, please assist
Old Aug 19, 2011 | 10:36 PM
Jaded's Avatar
Jaded
My trans was doing that after a dealer service. Idiots filled the fluid up to the full mark while idling in park. The stick clearly says "check while idling in neutral". After adding fluid, that kick was gone.
Old Aug 20, 2011 | 11:46 AM
Jeremysp1993's Avatar
Jeremysp1993
Originally Posted by EliteTempleton
Washer nozzle: maybe clog but you say you have some water, I wonder if it's pressure? I don't know what part gives the pressure but I'd have a good look at it.
If you think clog, maybe a bunch of rubbing alcohol in your fluid & then of course button pressing. We use rubbing alcohol in crazy cold all the time so I know it's safe for the lines. Don't burn out you motor though.
CLR could work. Do be cautious of fumes if you go that route, not sure how that'd mix with whatever you already have in your lines.
mine was clogged a few times, so I used my air compressor with the blower tip and pointed into nozzle and the clogging went away, probably went through the other nozzle.
Old Aug 24, 2011 | 04:28 PM
saranym80's Avatar
saranym80
thanks for the input guys...so just that im not confused...speaker size is 6.5 all around?
Old Aug 24, 2011 | 06:06 PM
Altair's Avatar
Altair
Dak attack!
Yup, front and rear is 6.5" I wrote up a DIY on changing the front speakers awhile back, had planned to do one for the rear speakers as well but when I got around to starting it I realized I'd lost the pictures I took for it. Here's the fronts:
https://dodgeforum.com/forum/3rd-gen...by-altair.html
