Getting ready to change my rotors and pads. Which bolt to loosen?
I will have to disagree with this statement. Every time you remove the caliper to do brakes, you should pull the slide bolts (the two small ones in our case) clean all the old grease out, and check the slides for wear, and re-grease them. When I say clean them, I really mean clean the snot out of them. The old grease will be full of metal partials that will wear on the pins and caliper bracket.
Did you use the old wheel barring? I know the rotors from Brake Performance come with new pressed in barring races but they told me you will have to use the old barring or buy new replacements. Did you purchase new replacement clips? If so did you buy dealer clips or local parts store. Did anyone change out the rear drum brakes? I ordered replacement drums and premium shoes with a hardware kit from Brake Performance.
Wheel bearing pressed into the rotor??? Our truck has the bearing pressed into the hub assembly not on the rotor. I bought replacement clips from the dealer, original ones should work if they are not destroyed.
Older thread, I know. But it is a great thread for first time brake jobbers so I'm ok with reviving it for those who are talking about brakes. My first time doing brakes on a newer vehicle, so this information will help a lot.
I've done brakes and rotors before, but on older fords from early 90s and late 80s. Those all had rotors that doubled as the wheel hub with pressed in races and such. They also had large codder pin style slides that just knocked out with a chisle.. An ugly brake/rotor job but gave you a chance to repack your hub bearings and check the condition of all that.
Yea a lot of newer vehicles are doing it this way. It makes it a lot easier on shops and DIYers a like. I'm pretty sure my 08 Kia is the same. I sure am glad though, i'd rather not repack bearings if I don't have too.
