Outdoor Temperature Sensor
Old Sep 18, 2011 | 02:11 PM
Longlivedakota's Avatar
Longlivedakota
Default Outdoor Temperature Sensor
So I've searched and searched and searched; and I have found no help with my problem. So the situation....My Dak is equipped with an outdoor temp sensor which displays the outside temp on my instrument cluster. Well about 50% of the time that I start the truck it is stuck at the last temperature that it was at when I turned the truck off. So I could be 90 outside and it reads 70. Well the problem is, this should update after 5 minutes or so, right? Wrong...Sometimes it takes up to 30 minutes of driving before it starts to display the real temperature. I asked Dodge and they said that it might be a faulty temp sensor. Does anyone else have a solution before I go and replace the sensor?
Old Sep 18, 2011 | 02:34 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
disconnect the battery for an hour or two and then reconnect it.
Old Sep 18, 2011 | 02:40 PM
Longlivedakota
I'll try that. Thanks!
Old Sep 18, 2011 | 02:45 PM
wingman_214's Avatar
wingman_214
I've had the same issue as you and removing the battery cables fixed it right up.
Old Sep 18, 2011 | 02:48 PM
Longlivedakota
Perfect! I'm going to do that right now. That makes me happy that it is most likely something that I wont have to spend more money on.
Old Sep 18, 2011 | 09:29 PM
ericemery's Avatar
ericemery
Retired Administrator
Hall of Fame Member
those sensors are easy to swap out, and they should only be like 20 bucks.
Ambient air temp sensor.
http://cgi.ebay.com/ebaymotors/TX49-...item3ef149de9b
Old Sep 19, 2011 | 09:19 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Mines done this once or twice... a restart and reset should do the trick.
Old Sep 19, 2011 | 11:53 AM
KS Cowboy's Avatar
KS Cowboy
Is that located right behind the grill right infront of the lower radiator core support?
Old Sep 19, 2011 | 02:46 PM
ReturnToSender's Avatar
ReturnToSender
Yes, that's the one
Old Oct 7, 2011 | 02:21 AM
Longlivedakota
Thanks again, that fixed it right up!
