3inch pa lift
on
Now think about this........ How is it possible that the hitch hangs lower with a body lift?
The hitch is the same place it always was, the body is raised 3". But yeah, because the body is higher, it has the APPEARANCE that the hitch and all the suspension components, frame, etc. sit lower.
I read the other day on a 4x4/off-road based forum where a guy told another guy not to do a body lift because it would kill his angle of departure due to the hitch being lowered. I was like "huh??? ", so it needs to be clarified that the hitch or any other frame mounted components stay where they always were, the body just goes up.
That's the reason I stopped with 4" of suspension lift. I would have loved to add a 3" body lift and gone to 37" tires, but I have a frame mounted grill guard/winch mount and what the hell do you do with that? I'd have to completely fab/hack the front of the truck to retain them...
Good luck with your lift. I think I will wait on mine till I get the struts... Might as well just deal with that mess one time. lol
i dont have a lot of pics so just take a look at the one in my sig. the body lift was pretty easy to install with the help of a buddy and the tools at the auto hobby shop on base. it took us about a day. i was missing some nuts and bolts in my kit.... nothing major. just some that you need when you cut the radiator support mounts. some redneck egineering with some small tow straps held that in place till i was able to get the right bolts to put it back on. took us a bout the same time....bout 9 hrs... give or take. i highly recomend the PA body lift.
on
Yeah it's a full day job with a "helper". I've never gotten one done in one day, but always had it about done with just some odds and ends to do the next day.
On a full size truck at least, it's a good 8-10 hour job. I've seen 4x4 shops get 'em done in 5 hours, but that's with two seasoned mechanics working together and having the benefit of a vehicle lift.
Plan for a full day but don't plan on using the truck to go to work early the next morning, just in case you don't get done...
