Noisy front end/ suspension
Old Oct 31, 2011 | 01:36 AM
Jetster220's Avatar
Jetster220
Default Noisy front end/ suspension
My truck is a '06 3.7 with 53k on it. It makes a fair bit of rattling like noises and squeaking over any type of bumps in the road. Any ideas as to what could be causing the noises or what the fix is?
Old Oct 31, 2011 | 01:47 AM
projektdirtfab's Avatar
projektdirtfab
the first thing i would check is the steering. these new dakotas are pretty famous for having junk tie rods and ends. does the steering wheel feel like it wants to go wherever it wants when hitting bumps? if not than it could be bushings or balljoints. i ditched the stock steering tie rods and tie rod ends and i dont get rattles or wander anymore.
Old Oct 31, 2011 | 01:58 AM
Jetster220's Avatar
Jetster220
No, the steering wheel still feels pretty solid when going over bumps, at least I think so, like what exactly do you mean when you say does it feel like it goes where it wants?
Old Oct 31, 2011 | 02:24 AM
projektdirtfab
Like if the steering wheel jerks really quick when you hit a bump or jerk to one side
Old Oct 31, 2011 | 03:58 AM
marcsnyder05's Avatar
marcsnyder05
I had the same problem and I just got my right front cv shaft changed under warranty and now no more noise I would check your cv shafts
Old Oct 31, 2011 | 01:16 PM
Jetster220's Avatar
Jetster220
Oh okay, nope, steering wheel doesnt jerk at all when going over bumps stays straight.
I know its not CV joints as my truck is not 4wheel drive.
Old Oct 31, 2011 | 04:46 PM
cheeseburger's Avatar
cheeseburger
check for play in your tie rod ends and ball joints. http://www.youtube.com/watch?v=Ijn5Can276U
http://www.ehow.com/how_2175979_check-ball-joints.html
Old Oct 31, 2011 | 06:53 PM
ball joints too
Old Nov 1, 2011 | 09:52 AM
Robk1971's Avatar
Robk1971
I have the same thing going on right now but no rattles. Mine creaks so bad as a result of a bad ball joint on the drivers side I won't drive the truck anymore until I fix it.
Old Nov 2, 2011 | 02:40 PM
sawfish's Avatar
sawfish
What is your tire inflation pressure? Overinflated tires can cause the condition you mentioned when hitting bumps i.e. "bumpsteer". Use the pressures on the door jamb of your truck.
