08+ Exhaust size
Old Nov 8, 2011 | 10:15 AM
peoples1234's Avatar
peoples1234
Default 08+ Exhaust size
I have tried searching, but didn't find a specific answer.
I want to order a borla muffler to replace the factory one on my '11 Dakota, but I read (somewhere) that the exhaust pipe size was bigger than 2.5" but I could not find a concrete number.
Does any one know?
Thanks.
Old Nov 8, 2011 | 10:48 AM
Dakkkota's Avatar
Dakkkota
option1 remove big front muffler and leave juste rear resonator...or go true dual 2.5 in out muffler and cut off the Y pipe.
Old Nov 8, 2011 | 10:49 AM
Dakkkota's Avatar
Dakkkota
i am using dynomax tailpipe and bought a X muffler custon fab the dual in a shop total 700$
Old Nov 8, 2011 | 11:34 AM
dakotaff's Avatar
dakotaff
I put on a Magnaflow single in/single out, 2.5 inches on both end.
I don't think the exhaust size has changed since 2005, or earlier.
Old Nov 8, 2011 | 12:18 PM
Dakkkota's Avatar
Dakkkota
the res is still there?
Old Nov 8, 2011 | 12:27 PM
dakotaff's Avatar
dakotaff
I had 2 resonators, removed both of them.
Old Nov 8, 2011 | 09:03 PM
rebel4055's Avatar
rebel4055
Both resonators are removed on my truck too, has a flow master series 10.
Old Nov 9, 2011 | 10:01 PM
JimBio's Avatar
JimBio
08+ has 2.75" exhaust, it's just a hair larger then 2.5"
I installed a 2.5" Borla Muffler (the straight thru design) on mine (kept the resonators) it was just barely louder then stock, while cruising you couldn't tell any difference.
Removed the larger resonator and it gave it a deep rumble and is somewhat loud when your on it. I like it a lot.
You could use 3" as well, any good muffler shop can stretch a pipe section to make it fit. Either way it will take some custom work, don't plan on doing it yourself. My shop only charged $40 for a muffler swap.
Old Nov 10, 2011 | 08:33 AM
peoples1234
Thanks, that was the info I was looking for.
Old Nov 10, 2011 | 09:57 PM
sullysdetailing's Avatar
sullysdetailing
Pm sent about the Single 3'' MBRP 409 Stainless
