Question about factory remote start
Old Nov 13, 2011 | 09:26 PM
Haas1962's Avatar
Haas1962
Default Question about factory remote start
I'm sure having trouble getting this question on the board but I'll try again.
First I was in the wrong forum, then I moved it to this forum, now it appears to be gone altogether.
Anyway, I was wondering if the remote start has a time limit as to how long the vehicle will stay running?
I've started mine in the past to sometimes find the truck had shut off by the time I get in it.
Is it supposed to do that? Can I adjust the amount of time?
Old Nov 13, 2011 | 10:18 PM
marcsnyder05's Avatar
marcsnyder05
The manual says it will run for 15mins. And then it will run for a minute after you unlock it or open the door I don't remember which one. I don't know how to change the time limit or if you can. Hope this helps.
Old Nov 13, 2011 | 10:29 PM
Haas1962's Avatar
Haas1962
Thanks, it helps a lot. I don't have a manual, so at least I know this is normal.
Old Nov 14, 2011 | 03:29 AM
marcsnyder05
No problem I think you can download the manual somewhere on the here.
Old Nov 14, 2011 | 07:56 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Thats right, and if after the 15 minutes you restart the truck with the remote, it'll run another 15 minutes. Once that second 15 minutes is up the truck will not remote start again until the truck is at least cycled with the key. There are other conditions as well.
This is out of the owner's manual:
Your vehicle may be equipped with a remote starting system, which will allow the vehicle to be started from distances up to approximately 300 feet way from the vehicle using the remote keyless entry key fob which is part of your ignition key. In order to remote start your vehicle, the hood, and all the doors must be closed. To remote start your vehicle, press the REMOTE START button on the key fob twice within three seconds. To indicate that the vehicle is about to start, the parking lights will flash and the horn will sound briefly. Once the vehicle has started, the engine will run for 15 minutes. To cancel remote start, press the REMOTE START button once. To enter the vehicle while the engine is running during a remote start, you must first unlock the vehicle using the
UNLOCK button on the key fob. After the vehicle is unlocked, you have 60 seconds to enter the vehicle, insert the key in the Ignition and move it to the RUN position, otherwise the engine will cancel remote start and automatically turn off.
Remote start will also cancel if any of the following occur:
• If the engine stalls or RPM exceeds 2500
• Any engine warning lamps come on
• The hood is opened
• The hazard switch is pressed
• The transmission is moved out of park
• The brake pedal is pressed.
The vehicle can be started remotely up to a maximum of two times. The vehicle is also allowed a maximum of one failed start, where the remote start sequence was initiated but cancelled before the engine begins to crank. After either of these conditions, or if the Vehicle Theft Alarm is alarming, or if the PANIC button was pressed, the vehicle must be reset by inserting a valid key into the ignition and moving it to the RUN position, then back to LOCK. The parking lamps will remain illuminated to indicate that the vehicle has remote started and the engine is running. The lamps will turn off when the ignition is turned to RUN or the remote start is cancelled.
Old Nov 14, 2011 | 10:28 AM
Haas1962's Avatar
Haas1962
"Awesome, thanks guys!!
Old Nov 14, 2011 | 10:36 AM
DM_kota's Avatar
DM_kota
For those of us w/o remote start... is it possible to add it on to the oem system?
Old Nov 14, 2011 | 10:42 AM
MitsuRaider's Avatar
MitsuRaider
It would be awesome if I could warm up the truck from inside the house!!
Has anyone done this before??
Old Nov 14, 2011 | 11:52 AM
DM_kota's Avatar
DM_kota
From what I have heard we can't put a aftermarket starter in, but my logic us that the programming and wiring should mostly be there right? We just have to put in the right missing prices?
Found 2???
http://www.dodgepartsstore.com/produ...oducts_id=1559
http://outtendodge.oemdealer.com/adv...=&pto=&x=0&y=0
so maybe it is all plug and play??? just need a 4 button key or the remote start button.
Old Nov 15, 2011 | 11:42 AM
dakota_raven's Avatar
dakota_raven
I love it! I do it every winter and in the summer heat of Texas is awesome!!!!
