2010 w/ 2'' front lift kit?
Old Nov 21, 2011 | 11:24 PM
victorjg's Avatar
victorjg
Unhappy 2010 w/ 2'' front lift kit?
Hi:
I own a 2010 crew cab dakota, is time to change the tires and I was thinking in upgrade them a little taller, right now is using 265/65/17, pepboys and many others offers 265/70/17. this size really fit without any rub?
Now how it will look with a 2'' front lift kit and put some 32x10.5/17?
Does anyone have pictures of it and can tell me if they affect in some way the ride or some suspension parts?
Definitely if I don't buy the lift kit I'm going to buy the 265/70 in A/T version.
Does anyone can help me on that?
Thanks anticipated,
Victor G.
Old Nov 22, 2011 | 08:49 AM
dakotaff's Avatar
dakotaff
A 265/70/17 tire would require a leveling kit installed. And you would probably still have to trim some of the front wheel splash guard and wheel well liner.
265/70/17 is about a 31.5 inch tire, I'm running 2 set of tires with a 1.5" leveling kit, 285/50/20 and 265/70/17, and both sizes required trimming.
The leveling kit probably wears the front end out faster than without, but plenty of us do not have problems at all.
The front end suspension of the Dakota isn't the best to begin with.
Old Nov 23, 2011 | 08:44 PM
victorjg's Avatar
victorjg
Hi:
Thanks for the advice, did you know where I can find a 1.5'' front leveling kit? 2'' is the only one I have found on internet..
A 1.5'' will be the perfect one for me..
Thanks
Victor G.
Old Nov 23, 2011 | 09:07 PM
dakotaff's Avatar
dakotaff
It's the Trailmaster leveling kit, #DL223.
http://www.autoanything.com/suspensi...8A2343144.aspx
Not exactly sure who is selling the cheapest nowadays.
Old Nov 24, 2011 | 12:11 AM
victorjg's Avatar
victorjg
Hi:
Thanks for the comments and experiences, but that Trailmaster leveling kit, #DL223, doesn't fit in my 2010.
I will continue the search thanks..
Victor G.
Old Nov 24, 2011 | 08:29 AM
I've got the 2" daystar kit and 265/70-17 tires (31.6" diameter). I had to trim the lower inside edge of the splash guards. Thats the only place it rubbed.
Old Nov 24, 2011 | 10:13 AM
Dakkkota's Avatar
Dakkkota
2.5 1.5 rough country 199$ front + rear
Old Nov 25, 2011 | 09:39 PM
victorjg's Avatar
victorjg
Hi:
I'm really confuse almost everybody even with the leveling kit have rub with
tires of 265/70/17 size... just almost one inch of difference in tire size and all this kind of problems I really don't know what to acquire to have no problem at all with this size of tire an most important, have my truck a perfect leveling suspension and look!
Thanks
Victor G.
Old Nov 25, 2011 | 11:08 PM
EdHoffman68's Avatar
EdHoffman68
Default Softer springs without loss of height.
Does anyone know where to get some soffter coilspring for a ram 2009 2wd without losing any of the factory height?
Old Nov 26, 2011 | 09:08 AM
dakotaff's Avatar
dakotaff
Originally Posted by victorjg
Hi:
Thanks
Victor G.
It's not a lot to trim from the front splash guard, you won't notice it at all when looking at it.
This is all that I had to trim, this was to fit my 285/50/20 tires. The 265/70/17 fit easily afterwards without any other trimming needed.
The green is the area of the front splash guard that I had to trim.
The yellow area is what I needed to trim from the front wheel well liner. You might not even have to touch the wheel well liner, my 285's were wider and required the trimming for full turns.
