mustang injectors
Old Nov 25, 2011 | 04:32 AM
marcsnyder05's Avatar
marcsnyder05
Default mustang injectors
I've been thinking about gettting some of the SVT corba 39lb injectors and putting them in when I install my H/O cams and swap to a SCT tuner this spring For those y'all that are running them where did you get them and how much did you pay? if you don't mind my asking. I found these on ebay but I don't know what is a good price.
http://www.ebay.com/itm/03-04-Mustan...ht_1876wt_1163
Old Nov 25, 2011 | 11:14 AM
Hahns5.2's Avatar
Hahns5.2
Way too big, totally unnecessary.
Old Nov 25, 2011 | 12:47 PM
MitsuRaider's Avatar
MitsuRaider
I got mine used for 100 bucks nd that was a ppretty good deal. I needed bigger injectors to make up for the air ratio increase.
Without more air bigger injectors wont make your truck faster. Your will just run rich.
Old Apr 29, 2015 | 09:50 PM
Dakotalife06's Avatar
Dakotalife06
Default 39lb injectors
I have a question I put 39lb injectors on my truck today now it does run rich as hell did when I first started it. It was hard to start but after it did I drove and it drove fine and actually it gave me power no lie could do something I never could a "burnout!!" But the big problem is I believe the fuel/air ratio is way off if I stomp it it goes like a bad out of hell then at about 5,000 rpms it cuts out not sure if the ratio is off or the fuel pump can't keep up hopefully tall do and it is throwing rich codes
Old Apr 29, 2015 | 10:07 PM
Right. It will and it does. You're just going end up carboning the heck out of your engine. As stated, it is a waste of money and gas unless you are going turbo or supercharger. You've done nothing to increase the air required for more fuel. You're better off with a tuner. Welcome to the forum.
Old Apr 29, 2015 | 10:20 PM
Dakotalife06
Thanks man and thank you for responding what is the best way to get mor air flow through the motor only thing I can think of is a cai
Old Apr 29, 2015 | 10:26 PM
That won't help. You need more volume. Bigger throttle body, intake manifold and head work. You need to get the stoichiometric ratio Back to 15:1 for complete combustion. Might be able to get a custom tune from hemifever, can't remember though.
Old Apr 30, 2015 | 09:01 PM
superdak05's Avatar
superdak05
with the HO cams bigger injectors are not needed, a simple tune with the cams is what will wake the truck, I went larger 206 cams along with a 70mm tb for my nitrous, hence the larger injectors were needed, new they ran me almost 400.00 from the local dealer, and with the sct tuner from Sean, most R/T charger and challenger people don't know what hit them
Old May 5, 2015 | 02:40 PM
Jeremysp1993's Avatar
Jeremysp1993
I wanna try the factory 19lb injectors from the 4.6 motors on my truck, same thing as the 39 but less fuel but should have the same spray pattern but still definetly better than my 3.7 spray pattern. Computer will compensate to an extent for fuel but i believe our dakotas are 17 or so annyways?
