Max front lift for 2wd
Old Nov 27, 2011 | 03:47 PM
dsimm87's Avatar
dsimm87
Default Max front lift for 2wd
I'll be adding a front leveling (lift) kit pretty soon and I want the most I can get within reason. I was just wondering what yall thought of a 2.5" or a 3" over the strut spacer.
For those with the 2" front lift, do you think I could squeeze in another .5-1"?
I have a 2wd and I never go off roading. I do go over a few curbs (intentionally and slowly) now and then and that's about it.
thanks!!
Old Nov 27, 2011 | 03:53 PM
Reject's Avatar
Reject
The bigger it is the more angle it puts on front parts = Premature wear. I think 2wd can do 3" but you might hit the spring over bumps due to the angle of the control arm. 4x4 cant do over 2" I think it is without CV problems. Personally I wouldnt put more then a 1.5" or 2" on my 2wd and I off-road occasionally.
Other guys who have a lift could have better info then me, but thats just what I have read on here about them.
Also I heard guys suggest replacing your front struts at the same time, and sometimes the mounts to since its all apart
Old Nov 27, 2011 | 04:05 PM
Dakkkota's Avatar
Dakkkota
2,5'' is 1.5'' thick
Old Nov 27, 2011 | 04:26 PM
FrenicX's Avatar
FrenicX
2wd? Just lower it!
Old Nov 27, 2011 | 04:44 PM
dsimm87's Avatar
dsimm87
I'm putting ranchos up front and monroes in the rear this december, then when I need new tires (within a few months), I'm gonna get the lift. I wanted some opinions before it got to that point tho. Thanks for your input. I was weary on the 3" myself... (thats what she said)
Is there a point? I already know that the width of the spacer is less than the lift of the truck. Are you saying a 2.5" spacer would be fine (in your opinion)?
Originally Posted by FrenicX
2wd? Just lower it!
I thought about that but I like the height.. I'm 6'6" tall, it would look weird, me gettin into a low rider, haha
Old Nov 27, 2011 | 04:52 PM
dakotaff's Avatar
dakotaff
I wouldn't go any bigger than the 2" spacer, that is plenty.
Old Nov 27, 2011 | 07:16 PM
I cant remember but if you go 2" with a 2wd you might also have to put blocks in the rear or the front will be higher...or is that with a 4wd?
Old Nov 27, 2011 | 07:25 PM
Reject's Avatar
Reject
I thought both were the same height, Ive yet to find a 4x4 higher then my 2wd, lol
Old Nov 27, 2011 | 07:39 PM
dakotaff's Avatar
dakotaff
I'm pretty sure they are the same too.
Old Nov 27, 2011 | 07:40 PM
FrenicX's Avatar
FrenicX
Agreed, 2nd gens for sure. But I too have never seen a 4wd taller than me. That should change soon though!
