Leaking water pls help
Old Jul 17, 2012 | 05:29 PM
Deer Hunter's Avatar
Deer Hunter
Originally Posted by gunner44
I have the same problem. how do you clean the drain tubes?
Try plastic string from a weed whacker, it's heavy and flexable.
Old Jul 18, 2012 | 06:53 AM
gunner44's Avatar
gunner44
Default Dodge Roof Leak
I cannot find the drain tubes in question. Can someone direct me to their location?
Old Jul 18, 2012 | 07:25 PM
Rocky4052's Avatar
Rocky4052
Check where your front door hinges attach to the body. Halfway in between the 2 hinges there is a (might be) rubber hose coming thru a rubber grommit. I have these on my 07 quad cab, at both front doors, but haven't been able to find out where they drain from. All I know is I did get crap out of them with trimmer string. (water and dirt) I do have an opening sun roof, so they could be from there. Also resealed weatherstriping above doors on the body and my leak problem seems to have been cured.......Hope this helps???
Old Jul 19, 2012 | 07:27 AM
gunner44's Avatar
gunner44
FOUND IT! Thanks, going to buy trimmer line now in hopes it solves this issue. Thanks again for your help.
