Leaking water pls help
Old Dec 1, 2011 | 11:05 PM
Devan17's Avatar
Devan17
Default Leaking water pls help
I am new to the forum and my question is... I have a 2006 dodge Dakota 4dr and when we have a heavy rain my floor boards under my Matt's are really wet and if it rains hard enough water drips from where the seat belts attach to the truck at the top... I do have a factory sun roof and have had the drain tubes cleaned about 2 months ago and I am having this problem again but only during hard rain storms.... Would it be the tubes again? What do I do to fix it without having to clean the tubes every couple months if that is the problem? Thanks...
Old Dec 1, 2011 | 11:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 3rd Generation Dakota sub-section.
Old Dec 2, 2011 | 01:15 AM
FrenicX's Avatar
FrenicX
https://dodgeforum.com/forum/3rd-gen...eaking-in.html
Here's another thread about the leaking. There are some different theories there that might help you. My guess is the drain tubes though, do you park under trees a lot?
Old Dec 2, 2011 | 02:36 PM
Devan17's Avatar
Devan17
Yes, my whole drive way and yard is covered by 4 very big trees... Thats why I asking if it is the drain tubes then is there something I can do to reduce the problem other than cleaning the tubes every couple months or another replacement hose that is better than the factory drains... My wife has a Toyota celiac with sun roof and parks in the same area and never has any leaks or anything...
Old Dec 2, 2011 | 03:04 PM
Backwoods18's Avatar
Backwoods18
I will agree with it being your tubes but can't help out with a solution besides cleaning them lol
Old Dec 9, 2011 | 01:54 PM
Devan17's Avatar
Devan17
Sorry for the delay... I have cleaned the lines water ran straight through them nothing came out except water and it was clean looking water. I did not see any dirt or discolored water come out... What should I do next?
Old Dec 9, 2011 | 02:28 PM
Dakkkota's Avatar
Dakkkota
i want to join thin in case someone find a solution same problem here
Old Dec 11, 2011 | 08:55 AM
damyankee84's Avatar
damyankee84
I have the same problem but only when I park the truck pointing up hill when it rains real hard. Also no sunroof here.
Old Dec 13, 2011 | 06:38 PM
Devan17's Avatar
Devan17
Ok I think I have solved the problem... I just fixed it today so waiting on some rain to test it but this is it... Sorry I dnt know technical terms... It was the rubber seal on the door there are two of them but I am talking about the first one had no water sealant put on it when I had work done to the truck and water was running behind it to the second rubber trim and at the bottom where the rubber is split leaking through there into the carpet... Hope this make since to everyone and helps y'all out
Old Jul 17, 2012 | 03:51 PM
gunner44's Avatar
gunner44
I have the same problem. how do you clean the drain tubes?
