A minor inconvenience....
Old Dec 11, 2011 | 11:27 AM
MitsuRaider's Avatar
MitsuRaider
Default A minor inconvenience....
Ok so I had a little set back this morning.
I noticed that the "T" I installed at the oil pressure sensor to feed oil to the turbo was a bit loose, so I went in there to tighten it up.
It's right on top of the oil filter.
Well I ended up breaking the thread inside the block
What do you guys think I should do? I'm guessing I'll have to replace that whole part...
Old Dec 11, 2011 | 11:50 AM
EliteTempleton's Avatar
EliteTempleton
Dremel a slot so you can unscrew it with a flat/straight head screwdriver, or a chisel
Old Dec 11, 2011 | 12:26 PM
Alfons's Avatar
Alfons
Since that fitting end already has a hole in the center and shouldn't be seized, I would use a good quality easy-out to unscrew it from the block - just be careful not to over stress the easy-out and use the largest that will fit. If you snap the easy-out, the whole thing will be harder to remove.
The fitting itself will need to be replaced & you should be able to find another at any hydraulic shop. Get some teflon tape as well, you wrap some around the threads and they help seal them when you screw the fitting in & you won't need to put so much stress on the new one when you put it in.
Old Dec 11, 2011 | 12:51 PM
Dakkkota's Avatar
Dakkkota
did you mentionned GOOD quality EASY OUT!!!!!
lol i just want to repeat it :P
Old Dec 12, 2011 | 07:03 AM
MitsuRaider
those are some great ideas guys, I have been looking into the easy outs online.
Elite, your idea might work as well. i just have to see what will work better in there since i don't have much room
Old Dec 12, 2011 | 07:44 AM
Blown287's Avatar
Blown287
I would try an easyout. If that doesn't work, I would talk to a machinest and show them the pics. You definately do not want to damage the threads.
Old Dec 12, 2011 | 08:28 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Go to your nearest Advance Auto Parts. They carry Irwin tools on the floor, including easy outs.
Old Dec 12, 2011 | 09:31 AM
EliteTempleton
I've never heard of an easy out before, learn something new every day!
Old Dec 12, 2011 | 10:33 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Get a good easy out for sure. Cheap ones will make things worse, dont ask. Craftsmans and Snap-on both have them for reasonable prices.
http://buy1.snapon.com/catalog/item....&group_ID=1262
http://www.sears.com/craftsman-4-pc-...p-00952155000P
There are numerous other style extractors by both, too
I have used the hex head styles as well and they are pretty amazing
Old Dec 12, 2011 | 10:46 AM
DakotaAgain?'s Avatar
DakotaAgain?
These so called easy outs work best on TV infomercials.
