Towing with Electric fan
Old Dec 14, 2011 | 10:41 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Is your rad plugged with mud or something? The fan should only run on occasion. The rad should do most of the work.
Mine only ever bumps up to half while towing. Make sure you keep the rpms up to circulate the fluids and keep it working.
Old Dec 14, 2011 | 10:46 AM
Dakkkota's Avatar
Dakkkota
rad is clean... the temp is super low except when i tow
Old Dec 14, 2011 | 10:48 AM
EliteTempleton's Avatar
EliteTempleton
Question
Originally Posted by Dakkkota
the temp reach 3/4 while i tow 2 ATV+1 motocross + clothes + Food wile i passed trough mountains up and downhill...with the standard fan 1/2...i have the 180 thermostat to...usually its 1/4.
Does your truck have a SPAL controller?
Old Dec 14, 2011 | 11:01 AM
Cuban11182's Avatar
Cuban11182
I've received order to Corpus Christi. I'm going to be in charge of the Engineering shop on a Coast Guard 87" ship.
Old Dec 14, 2011 | 11:11 AM
Dakkkota's Avatar
Dakkkota
its derale
Old Dec 14, 2011 | 12:54 PM
Cuban11182's Avatar
Cuban11182
I'm going to change out my water pump to the GMBH (name?) with the metal impeller. Before, when I had the taurus fan and the derale controller I towed about 6000lbs across NC (level ground), but didn't overheat. This was in the fall though.
Old Dec 14, 2011 | 01:25 PM
EliteTempleton
Water pump changes, fun fun...
Old Dec 14, 2011 | 02:08 PM
Talking
took me all of an hour at the most....one of the easier things to replace on these trucks...
Old Dec 14, 2011 | 03:09 PM
EliteTempleton
When I changed mine it was on my 02 Dak, so either it's easier on 3rd gen or it was hard because that was one of the first "big" things I ever did, ya know, beyond tire/oil/air filter change. Now that I think of it though, mostly it was getting the clutch fan off that was the frustrating part for me.
Old Dec 14, 2011 | 03:36 PM
Cuban11182's Avatar
Cuban11182
From what I've seen they are easy to remove. Drain coolant, remove belt, unbolt, bolt in new one, attach belt, fill back up, admire your work!
