Want both tires to spin!!!
Old Dec 20, 2011 | 08:26 AM
FrenicX's Avatar
FrenicX
Stick you an Auburn Gear LSD in there and be done with it, don't know it's in there when you don't need it but locks up pretty good when you do need it, just like the factory LSD SHOULD, but doesn't.
Old Dec 20, 2011 | 09:15 AM
I wish it was as simple as "sticking one in there". If it was a matter of removing the cover, unbolting one thing and bolting in another I would do it.
Old Dec 20, 2011 | 08:45 PM
GrnDak01's Avatar
GrnDak01
Default Lockrite
The lockrite is a "lunch box" type lock that is easy to put in. But as was mentioned the street manners of auto lockers and lincoln (welded) lockers can be unpredictable, particularly the lincoln since it doesn't give at all. The lockrite will and I would try that. Its a one man installation and is simple and strong and most of all much less expensie than the manual lockers. I don't know how it compares to the auburn price though. Best of luck.
Old Dec 21, 2011 | 09:30 AM
Dells33's Avatar
Dells33
I also thought the trucks had a stock LSD in them because I have No! problems with braking both tires lose! Matter of fact I can easily do donuts in 2nd gear on dry pavement and brake them lose by shifting from 1st to 2nd at 30 miles an hour on dry pavement. My truck is stock expect for the exhaust.
Old Dec 21, 2011 | 11:55 AM
FrenicX's Avatar
FrenicX
don't make us autos jealous.
Some of the trucks came with LSDs, they work just fine. Blown has videos of his 100 footers he made with stock LSD and automatic trans
Old Dec 21, 2011 | 12:04 PM
thunder98110's Avatar
thunder98110
the stock lsd's from chrysler arent that great. google: 9.25 diff c clip....and you will find hundereds of posts of people who have had their rear diffs explode. my stock lsd only behaves as an lsd when going straight, during a corner or snow, it acts as an open diff.
prime example here. 1 wheel peel with lsd.
http://www.youtube.com/watch?v=OAxkS...5&feature=plcp
Old Dec 21, 2011 | 01:45 PM
HammerZ71's Avatar
HammerZ71
Not only do the "C-Clips" fail at some point EVERY TIME, but even when working properly they have a very low bias ratio (meaning they will fail to hold lock when a certain amount of torque is applied to them) but they often need "help" just to engage. I found when I had the stocker I needed to apply either a little brake with the gas or slightly apply the e-brake to get it to engage. With the Auburn - it just works right...
Old Dec 21, 2011 | 02:05 PM
FrenicX's Avatar
FrenicX
C clip doesn't last for sure, and most stock LSDs won't lock when you try donuts, my S10 never would, but I had forward propulsion. My open diff would come to a stop until the inside wheel had traction again. That's also very terrible to do with stock LSDs, it's trying to lock and is slipping like mad and will give out easily.
By the way, I LOVE my new auburn. I can really feel the tightness of it just making regular speed turns. But it never hops, and still turns decently in snow under low power without losing traction. Kicks the tail out just when I want it to when I try and always launches with full traction or both loose depending on how mean I am to it. Funnest upgrade yet.
Old Dec 22, 2011 | 09:39 AM
superdak05's Avatar
superdak05
I have the factory corporate rear as chrysler calls it, never had an issue, took out the 3.55 and installed 4.10, best move yet, 116000 miles and it still breaks the back end loose when ever
Old Dec 23, 2011 | 08:54 PM
Barkleyfan's Avatar
Barkleyfan
Originally Posted by rengnath
And on top of being fun, it will let you live life on the edge by making driving in the snow down right dangerous unless you're in 4x4!
I suppose it depends on the rest of your setup. Compared to my 98 R/T, this thing is easy to drive in snow. I would take my foot off the brake and the rear end would walk out into the other lane at idle. The shift from 3- OD would break it loose at 35mph. But that had a shift kit, 10.5" street slicks, 3.92's, same power, and a LOT more torque.
That said, I DO like being able to throw it into 4WD on the fly. Hills still suck in snow with ANY 2WD, especially from a stop, posi or open.
