Ball joint advice
Tops arms and ball joints, no alignment needed.
Lower ball joints, you should have an alignment.
Might I suggest you replace both lower ball joints at the same time? You are going to play back-and-forth with ball joints if you do them one at a time. If one is bad, chances are the other one is close.
