Factory stereo I-pod wire
Old Jan 7, 2012 | 11:04 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Default Factory stereo I-pod wire
So...apparently my stock stereo has an open recepticle for the Mopar I-Pod cable. I plugged it in...nothing. Originally, I purchased the wire for my wife's 09 charger, since the parts dept. told me it was plug-n-play. Then, after that didn't work, they tried to star scan the SOB. That didn't work, so then they told me it needed the U-connect stereo to work. My question is, if my stock stereo has an unused recepticle that matches the damn I-Pod wire, then why won't this work? Does anyone have any experience with this?
Old Jan 7, 2012 | 11:46 PM
FrenicX's Avatar
FrenicX
Sounds like they are just dicking you around. Didn't work when they starscanned it so instead of fixing it they BS you saying you need a more expensive option. Did they charge you anything yet? I don't have one, but I really get tired of the stealer not just stealing our money, but our time too. That's where all the reject mechanics go when the world hates them.
Old Jan 8, 2012 | 03:29 AM
erau's Avatar
erau
Just throwing this out there, it may or may not be correct in your case...
I have seen a stock radio or two, especially GM/Delco, with extra receptacles for options I knew simply didn't exist on that specific radio...but by all accounts, it streamlined the manufacturing process and cost less to just let them all get punched with many of the same circuits, gadgets, and gizmos. (Probably like why my Dak came pre-wired for cruise control.) But I would guess the U-Connect chip and associated circuitry, as being the more expensive part of the radio, was left out, and it was the part that actually knew how to "talk" to your iPod.
There is a possibility the guy might actually be right.
Old Jan 8, 2012 | 10:37 PM
donkeypunch
King Jackass
Hmm. Didn't think about that one. That makes sense though. For F*ck's sake, why can't this be easier?
Old Jan 10, 2012 | 11:23 AM
08_Dakota's Avatar
08_Dakota
I just use the aux input jack on my daK to connect my iPod with the headphone jack on the iPod. Works fine.
Last edited by 08_Dakota; Jan 11, 2012 at 05:56 PM. Reason: Didn't notice i said day instead of dak
Old Jan 10, 2012 | 11:42 AM
Originally Posted by 08_Dakota
I just use the aux input jack on my day to connect my iPod with the headphone jack on the iPod. Works fine.
what?
Old Jan 10, 2012 | 01:18 PM
erau's Avatar
erau
Go aftermarket. If you already have the radio out, 80% of the work is done. Just gotta pick up a mounting bracket, wiring harness matching your desired radio manufacturer to dodge/chrysler, and splice the radio's red wire into the cig lighter's dark blue-pink wire for accessory on/off (truck's computer won't sense the factory radio, so it won't send the on/off signal the normal way). Make sure the cigarette lighter fuse position is aligned to have power "switched with the key", not "on all the time"...apparently not every truck has it positioned the same way from the factory):
At some point the factory radios began including the front aux input jack, but my 2005 didn't, and I'm assuming his 2006 didn't either. The change probably happened in 2008 with the interior/radio shape update.
Old Jan 11, 2012 | 07:27 AM
northgator8's Avatar
northgator8
My '06 has the aux input.
Old Jan 11, 2012 | 09:16 AM
donkeypunch
King Jackass
As does my 06.
Old Jan 11, 2012 | 11:35 AM
erau's Avatar
erau
As does my 06.
Well I'll be damed. Then why not just use it for the iPod?? lol
