Jmr
Old Jan 16, 2012 | 01:14 PM
Frankiejaime88's Avatar
Frankiejaime88
Default Jmr
Has anyone done the lift yet?
I was just wondering if there was any issues you ran into while installing it or even on down the road?
Hopefully by mid feb I can order my kit
Old Jan 16, 2012 | 01:36 PM
donkeypunch's Avatar
donkeypunch
King Jackass
I don't believe anyone has ordered one yet...at least on this forum.
Old Jan 16, 2012 | 02:31 PM
dakotaff's Avatar
dakotaff
Here is a recent thread on the lift.
Old Jan 16, 2012 | 03:40 PM
Frankiejaime88
Well hopefully I'll have it Installed by mid march at the latest with there 3 to 4 week build time once it's installed I'll post pics of it, won't really be able to get out on the trails cuz of all the snow until summer
Old Jan 16, 2012 | 05:08 PM
Alfons's Avatar
Alfons
With that lift, what are you planning for wheels? axle ratios? speed compensation module?
Old Jan 16, 2012 | 05:39 PM
Frankiejaime88
I'm gonna stay with 16 inch wheels 32 inch bfgoodrich tires doing 410 gears and recalibrating the speedometer and odometer for the bigger tires
Old Jan 16, 2012 | 06:58 PM
Alfons's Avatar
Alfons
You should have plenty of room for 32" wheels with that lift, and probably have room for larger should you want. I don't know what your current gear ratio is, so I couldn't do any calculations, but with 4.10 gears & 32" wheels, you should be close to a wash in terms of road speed. I'm assuming the after market gears are compatible with the Dakota speed sensor, so your shift points should be fairly close to what they were originally, but you may need a different "box" to reprogram the transmission if you find any lack of power with the larger wheels.
