really cold
Old Jan 19, 2012 | 02:10 PM
  #21
FrenicX's Avatar
FrenicX
Originally Posted by northgator8
1/2 as long as her volvo takes.
E-fan on the volvo?
Originally Posted by ballsout
the worst thing with the truck is how bad it freezes up though, can'y put my windows down and it sounds and feels like a tractor when i fire it up cuz of the coating of ice and crap on my exhaust hitting the underside of the truck vibrating.
I had the truck parked outside for a week or so while i was re-arranging stuff and I was surprised how little it takes to freeze those windows up solid.
Old Jan 19, 2012 | 02:43 PM
  #22
marcsnyder05's Avatar
marcsnyder05
Originally Posted by FrenicX
E-fan on the volvo?
Sometimes my windows will freeze up just from sitting all day or night depending on what shift im on
Old Jan 19, 2012 | 03:52 PM
  #23
northgator8's Avatar
northgator8
E-fan on the volvo?
e-fan, yes, but it has nothing to do with it!
E-fan has nothing to cool until the thermostat opens up and coolant flows through the radiator. Thermostat doesn't open until the temp is above 180 or 195 F (depending on the 'stat you have). 175 F is plenty warm enough to heat up the interior.
Up to normal operating temp also has nothing to do with the e-fan. It may cause the temp to go up, then drop down - and start a bit of a yo-yo until the system is all warm, but at -10 or -20, just the air moving through the rad will do that if you have any speed up at all.
My beef with Dodges in the winter is that the A/C is always on with defrost and can't be cancelled. I understand that it removes moisture from the interior air, but at -40, I need some heat on the windshield - NOW! And travelling down the highway, I need a little bit of air moving over the windshield at all times to keep it clear, A/C on all the time just sucks the gas!
Old Jan 19, 2012 | 04:16 PM
  #24
FrenicX's Avatar
FrenicX
exclamation point and everything?
as I understand it, a mechanical clutch fan adds drag to a cold motor to help warm it up. When it's not needed, or when the motor gets revved to a certain RPM, the clutch disengages until the temps are high enough for it to kick back on again while the thermostat is open.
..i guess i could be totally wrong though
Old Jan 19, 2012 | 04:35 PM
  #25
northgator8
Switching to a calm, quiet soothing font, and only using the punctuation that is really required, I'll confuse the issue with the science of physics. On your point of drag from the fan clutch I have to call male bovine solid waste. Hauling around nearly 3,000 lbs of truck puts way more drag on the motor than will an engaged fan clutch.
Sorry, I can't make the font smaller and readable. It is not bold, just the way the font works. And I forget what the calmest, gentlest font colour is.
(also, just yankin' yer chain, with the whole calm and soothing thing. An exclamation point doesn't have to mean a punch in nose . . .)
Old Jan 19, 2012 | 04:45 PM
  #26
Reject's Avatar
Reject
Originally Posted by SamuraiDak
Mine takes waaaaay longer to warm up, but then again, I'm from Canada and it has just hit 20 below.
Mine can idle for a good 5 minutes and still not even move the needle until I drive a few km.
Altho I just jump in it start it and drive away mostly all winter long unless its in the AM.
Also live in Canada, Where you at SamuraiDak? im in NS
Old Jan 19, 2012 | 05:06 PM
  #27
you forgot the elevator music...lol
Old Jan 19, 2012 | 05:21 PM
  #28
FrenicX's Avatar
FrenicX
I could hear soft trickling water and harp music, while a subtle aroma of lavender and chamomile filled the air while I read your post.
I am in a state of zen right now.. a place where trucks are 1700lbs lighter than normal and it all just makes sense.
(that was a light potshot at the 3000lbs thing, I understand you're a kilogram guy)
btw, it's just way too freakin cold up there man! If I were to check the temperature, and the Fahrenheit and Celsius are the same number, (-40) I'd just hibernate 'til it was over.
Old Jan 19, 2012 | 09:30 PM
  #29
SamuraiDak's Avatar
SamuraiDak
I live in Winnipeg or Winter-peg as is commonly known. Today hit -40 (with the windchill) which for you americans is the point where celsius and farenheit actually meet. I plug in my block heater any time the temps are -20 or more and the truck can run for 10 to 15 minutes before any heat comes. Fortunately I have the autostart so the truck is running for 15 minutes before I hop in. (NOT the best for gas milage lol)
Old Jan 19, 2012 | 11:22 PM
  #30
varnerhba's Avatar
varnerhba
just move to cali ha
