Closeout on headers!!
Old Jan 20, 2012 | 09:51 AM
  #21
varnerhba's Avatar
varnerhba
thank you sire the best 25$ I SPENT IN MY LIFE HA
Old Jan 22, 2012 | 12:47 PM
  #22
novovictus1's Avatar
novovictus1
Are these a direct bolt on to a stock exhaust? My particular concern was a 4x4 manual tranny, but its a steal for ceramic coated at that price.
FYI: From the JBA header install guide: "For 2004-2007 Dodge Ram, 2005-2006 Dakota, and Durango with 4.7L V-8 - Two and Four Wheel Drive"
Old Jan 24, 2012 | 11:47 AM
  #23
novovictus1
So I bought a set on Sunday but just got an email that they are actually out of stock
Old Jan 24, 2012 | 12:42 PM
  #24
FrenicX's Avatar
FrenicX
Oh damn, that sucks man. I was going to get a set but it will be wasted on my motor, since it's not going to be there :P
Old Jan 24, 2012 | 08:06 PM
  #25
damyankee84's Avatar
damyankee84
I think I got the last set....
Old Jan 25, 2012 | 12:52 AM
  #26
FrenicX's Avatar
FrenicX
Old Feb 4, 2012 | 09:24 PM
  #27
djsilver's Avatar
djsilver
Just got around to putting mine on yesterday. Mine's 2wd so no real challenge!
I started right after driving, while it was still hot (I've had better luck that way)
- Disconnected the battery, took the heat shields off and sprayed the bolts with rust buster while still warm.
- The two bolts at the rear are 12mm, the two bolts at the front are 13mm and the four in the middle are 10mm. The bolts to the y-pipe are 14mm.
- I never noticed till now that the motor is offset to the passenger side. The instructions recommend cutting off the extra threads on the rear-inside bolt for the passenger side strut-top. I'd recommend doing it before putting the header on. There's only about 1/4" clearance once the header is on.
- The instructions recommend removing the starter but I worked around it no problem.
- When bolting it back to the y-pipe, I recommend running up the top bolts by hand first, since they're harder to get to. Then you just have to tighten the bottom ones with tools.
The truck did feel perkier on the first drive but the real test will come when I do some towing. My car/trailer package weighs about 4,300lbs.
Old Feb 5, 2012 | 08:26 AM
  #28
should have taken pics step by step....I'm interested to see what the difference in the install is between 4x4 and 4x2 (I did it right Hammer!)
Old Feb 5, 2012 | 09:19 AM
  #29
Blu3P0ny's Avatar
Blu3P0ny
Totally waiting to see pics on install. I want these for my 4x4 but if it's gonna be a huge pain, I may go for the E-fan this year anyways. I have troubles pulling my 27' travel trailer through the "hills" towards the east coast when we go camping. Gets a little warm. Actually had to swap out plugs last trip only towing a 3000# boat.
Old Feb 5, 2012 | 10:49 AM
  #30
varnerhba's Avatar
varnerhba
tranny cooler....
