Installing Rear Blocks
Old Jan 20, 2012 | 08:12 PM
dsimm87's Avatar
dsimm87
Default Installing Rear Blocks
So, I have everything unbolted except for the bolt that holds the leafs together. The axle will not drop. So, I'm assuming I need to unbolt this too? It doesn't seem right since I would imagine the leafs uncompressing.
Thanks
Old Jan 20, 2012 | 08:19 PM
Alfons's Avatar
Alfons
Thanks
You need to clamp the spring pack together BEFORE you undo that centering bolt, otherwise you'll have a lot of difficulty putting all the leaves back together.
Old Jan 20, 2012 | 08:22 PM
Eimer123's Avatar
Eimer123
Ditto, use a clamp to hold the leafs together before you take that nut off. I learned that the hard way.
Old Jan 20, 2012 | 09:24 PM
dsimm87's Avatar
dsimm87
thanks for the help.
ok, so ive got the axle dropped... what do I do with those bolts?! do i remove them? I dont see how I can install the blocks with them in the way and then tighten the leafs back up (leaf bolts would them be too short)...
i think im missing something.... or have had too many beers!!
Old Jan 21, 2012 | 12:37 AM
dsimm87's Avatar
dsimm87
ok i figured it out
Old Jan 21, 2012 | 12:52 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
ok i figured it out
So did you a). Stop drinking or b.) Keep drinking???
Old Jan 21, 2012 | 03:41 AM
dsimm87's Avatar
dsimm87
kept drinking of course!!
Old Jan 21, 2012 | 11:03 AM
dsimm87's Avatar
dsimm87
Rear blocks and shocks successfully installed. Not too shabby for a first timer.
Old Jan 21, 2012 | 12:21 PM
clayh's Avatar
clayh
How does it ride with those shocks empty?
Old Jan 21, 2012 | 12:27 PM
dakotaff's Avatar
dakotaff
Nice job, but where is the completed side view picture?
