06 Dakota Rt rear blinker
Old Feb 3, 2012 | 08:14 AM
EastTN's Avatar
EastTN
Default 06 Dakota Rt rear blinker
The right rear turn signal does not blink. Whenever I make a right turn I get a fast blinking sound. The front works fine, except it flashes quickly. The rear light does turn on when the headlights or brakes are on but does not blink. Same when the hazards are turned on. The other 3 lights work with the hazards, but not the right rear. I replaced the bulb, and the same thing happens. Actually I replaced it twice, since the new bulb comes in a twin pack. Any help is appreciated
Old Feb 3, 2012 | 09:26 AM
norma jean's Avatar
norma jean
stupid question... positive they are the right bulb?
Old Feb 3, 2012 | 12:20 PM
varnerhba's Avatar
varnerhba
dido check the bulb number what do u have? 3157?
no question is a stupid question, some people arent familiar with wiring, vehicles or cars as some of us are, i could of said the same thing to alot of your threads, but i didnt, we are all here for help so watch it....its comments like that, that will push people away and you never know he could benefit all of us with some of his knowledge or willingness to spend his money with the help of other people's suggestments or whatever. I know I went to a forum one time, they dissed my post and I started a big deal and left. the guy has one post man comon....
Old Feb 3, 2012 | 12:25 PM
norma jean's Avatar
norma jean
Originally Posted by varnerhba
most likely your bulb is about to go out fully, most likely need to replace the one in the rear, should replace all of them at the same time.
check your bulb number im almost poisitive it should be a 3157, replace all your bulbs first and you should be golden, like 3 bucks a set at your local autoparts store, unless you want LED's.
sorry, didnt mean to come off as mean, my fault for wording it wrong
Old Feb 3, 2012 | 12:54 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
He meant he was asking a stupid question..not that the thread was a stupid question. Don't be so aggressive..
Old Feb 3, 2012 | 01:20 PM
DodgeCares's Avatar
DodgeCares
East,
Welcome aboard. I would tend to lean to the fact of it being a bulb as well and would also like to know what is the number bulb you used to replace the one that was not working?
Old Feb 3, 2012 | 01:28 PM
FrenicX's Avatar
FrenicX
Does the.new bulb ever work when you install it? The others blink faster because there is less resistance in the circuit. So its gotta be something with that socket or bulb type. You could switch the tail lights around just to test to see if its not in the wireing or canbus, if your other side works all hooked up then it must be the socket or bulb type.
Old Feb 3, 2012 | 01:30 PM
FrenicX's Avatar
FrenicX
I understood perfectly, varner is special.. or high.
Old Feb 3, 2012 | 02:57 PM
varnerhba's Avatar
varnerhba
**** now i feel like an *******, sorry norma i am high hope you accept my apology
Old Feb 3, 2012 | 04:55 PM
Backwoods18's Avatar
Backwoods18
Dude, really? When somebody goes off on someone like that (especially over a misunderstanding) around here (where I live), we take em out to a field set them straight...... Congratulations, It takes a lot to set me off and you just did it in 30 seconds
I got what you were putting down...
You should.....at least you apologized.
