Ball Joint ?
Old Feb 15, 2012 | 09:43 AM
KS Cowboy's Avatar
KS Cowboy
Question Ball Joint ?
When yall replace the lower ball joints, Do yall replace the entire control arm, or just the ball joint its self? Is there any reason to replace the entire lower control arm? Are there any other parts on the lower control arm that needs replaced? AND (final question, I hope for now) when doing the uppers, do i need to replace the bushings?
Thanks Yall!
Old Feb 15, 2012 | 09:59 AM
FrenicX's Avatar
FrenicX
Bushings come with the new upper arm and balljoint assy, lowers you can just get the balljoint, there are bushings but replacing those will mean you have to get an alignment, and chances are they are still good.
I would get an alignment for uppers anyways, personally. And I would also replace the whole lower arm too just because I'm thorough like that. Nothing feels better than a new front end. But that's just personal preference.
Old Feb 15, 2012 | 08:24 PM
BrandNew's Avatar
BrandNew
I replaced everything just like he said
Old Feb 15, 2012 | 08:56 PM
Eimer123's Avatar
Eimer123
I just recently replaced the upper control arms (Moog greasable ball joint included).
I also replaced just the lower ball joints (Moog greaseable) They press out and press in.
Old Feb 16, 2012 | 12:12 AM
KS Cowboy's Avatar
KS Cowboy
I was planning on getin the Moog greasable upper joint/arm assy. As well as moog greaseable lowers. I got the moog end links, and LOVE THEM! also thinkin of getin steering end links, monroe coil over rear shocks (hopefully this will help with load control), and rancho front struts with a 2" leveling kit (are KYB any good? I havent heard any definitive reviews on them.). Just gotta save up money for parts and tools. Most of it all from rock auto.
Is there any reason to replace the front coil springs?
Are the lowers difficult to replace, and would i need many tools to do that? I found this on harbor freight... http://www.harborfreight.com/automot...-kit-4065.html Would it be better to take the controll arm completly off and use a hydraulic shop press to punch them out. ( i just had the lower joints replaced this summer. Not sure that they are bad now, but while i got the truck apart, wanna fix as much as possible. )
I was planning on getin an alignment after i do anything. I need one now, but just dont wanna do it now then in 2 or 3 months do it again. (may look into lifetime alignment from Firestone)
Old Feb 16, 2012 | 12:56 AM
Eimer123's Avatar
Eimer123
You can press out the lower ball joint with the control arm in the truck. You will need a ball joint service kit like you linked but keep reading.
I will mention that you need the correct size receiving tubes or you will never get then in or out. You will need two different sizes. I really should have wrote down the sizes I used. I do not know if that kit will have the correct sizes.
Might be cheaper to see if your local autoparts has a larger ball joint service rental kit
You will also need a nice big hammer to knock the upper off. If you are going to replace the uppers and do not care if you trash the boot, go ahead with a manual of air hammer fork.
I really see no reason to replace the coil. I do not know the life span on them, but you are probably ok.
Old Feb 28, 2012 | 09:46 AM
Zombifyd's Avatar
Zombifyd
I didn't wanna start a new thread but will if I have to. When doing the upper control arms. Do I just jack up the car and fix it that way or just jack up under the control arm or both. I wanna do it myself very soon and want to know exactly what to do before I mess it up. Lol any help is appreciated.
Old Feb 28, 2012 | 01:09 PM
KS Cowboy's Avatar
KS Cowboy
For replacement, you would need to jack on the frame. If you jack on the controll arm, when you pop the top loose, it could fall on you. The strut can help support where the upper is, but its probably a better idea not to rely on that. But when re assembling the thing, it might be nice to have a jack to compress things.
How does one test their upper and lower ball joints, with out tearing the things apart? Is it better to jack the truck up, or do it while its on the deck?
Old Feb 28, 2012 | 03:13 PM
Zombifyd's Avatar
Zombifyd
Pretty much all mine have to be replaced... so as far as using a jack just jack it up like changing a tire and do it that way. And is it necessary for another jack to do the compressing or if you are strong enough can you do it with out an extra jack. Lol I know. I'm very slow. Lol
Old Feb 28, 2012 | 07:32 PM
KS Cowboy's Avatar
KS Cowboy
Jack it up and put it on blocks/stands, then use the jack to compress the spring/strut, but thats just me, im a bit of a weakling, and lazy.
