Looks good, not doing uppers or tierods just yet? I did the same, but I ended up having to do the lowers control arms, new alignment hardware, hub bearings, and lower strut bolts which wasn't a terrible thing but very difficult. Hopefully you don't have the same problem with your strut bolt that started it all for me. But you're in Florida, so I doubt you'll have rust problems.
Moog doesn't have one probably because the lower joint is replaceable with a moog one. The upper moog problem solver is the one you want for the upper.
I'm a bit confused, if i order 2 they will work on either side?
