Old 08-12-2015, 01:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Four Wheel Drive Guides
Print Wikipost
4wd low on dash is blinking
Old 03-29-2012, 08:23 PM
Rocket6R's Avatar
Rocket6R
Rocket6R is offline
New Member
Default 4wd low on dash is blinking
2011 Dakota Crewcab
When I put the 4wd indicator into low the 4wd low starts blinking on my dash. Is this normal?
Thanks, Paul
Old 03-29-2012, 08:29 PM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Dodge Forum Administrator
Does it ever go solid? And are you stopped or rolling?
Old 03-29-2012, 08:35 PM
CanadaDak's Avatar
CanadaDak
CanadaDak is offline
have you ever used it before? it flashes when it trys to engage.. you have to be at a complete stop and i think u have to be in nutral or park to but not 100% sure
Old 03-29-2012, 08:51 PM
norma jean's Avatar
norma jean
norma jean is offline
i believe you are correct.
lghtngblt02
Nah, no neutral or park, just a complete stop and if it by change does sense its ok when you are moving it's kinda harsh on everything.
Old 03-29-2012, 08:57 PM
norma jean's Avatar
norma jean
well then this saves me time, i always shift it in to neutral when i get stuck in my driveway, because its just mud, its been rather annoying, learn something new everyday, thanks
Old 03-29-2012, 10:08 PM
Rocket6R's Avatar
Rocket6R
Rocket6R is offline
New Member
It never goes solid. I have tried it both ways, stopped and rolling.
Thanks, Paul
Old 03-29-2012, 10:21 PM
Rocket6R's Avatar
Rocket6R
Rocket6R is offline
New Member
Ok! I just tried putting the truck into 4wd low while in park and the light still flashes. I then put the truck in neutral and the 4wd low now engages and the light went solid on the dash.
Looks like my truck will only engage 4wd low only when in neutral.
Thanks, Paul
Old 03-29-2012, 10:28 PM
jkeaton is offline
Mine is the same way. I can go into and out of 4-hi rolling, stopped, neutral, reverse, whatever, but to get into 4-lo, I have to come to a complete stop. Shift to 4-hi and let it engage, then shift into neutral and then turn to 4-lo. Been that way since I got it and it works the same way all the time. If I don't do it that way, the 4-lo will just sit there and blink at me.
Old 03-29-2012, 10:40 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
i didnt use my 4x4 for like a year then when I finally needed to use it it took a couple of days before it would engage on command, I find that a slight 1mph roll will help engage it into 4lo.
Quick Reply: 4wd low on dash is blinking
