Wheel/Tire Width??
Backspace and offset kind of work hand in hand. You only need one measurement when choosing a fitment for your truck.
If you can only get the backspace measurements of the new wheel, the most you can probably fit would be 6", on a 9" wide wheel. That 6" backspace would have an offset of 25mm.
But I'd definitely try to keep it at 5.5" to 5.7" on a wheel width of 9".
- On a 9" wide wheel (for example), an offset of 19mm gives you 5.7" (147mm) backspace.
- On a 8" wide wheel, an offset of 19mm wheel will give you 5.2" (134mm) backspace.
these are the wheels that you have to choose your backspacing
http://www.4wheelparts.com/Wheels/Bl...1638&w=2515-25
would i be better off with these and then just finding tires that fit?
http://www.wheelsnext.com/wheels-rim...%7C%20Red.html
That's more like it, good fit there.
Take your time and pick the wheels that you really like, you're going to be stuck with them for a long time.
Don't rush it.
