Wheel/Tire Width??
Old May 22, 2012 | 01:46 PM
  #21
KingsDodges's Avatar
KingsDodges
Originally Posted by dakotaff
That's more like it, good fit there.
Take your time and pick the wheels that you really like, you're going to be stuck with them for a long time.
Don't rush it.
thank you for your help
Old May 23, 2012 | 08:53 AM
  #22
KingsDodges
where did everyone buy their aftermarket wheels?
Old Jun 2, 2012 | 10:31 AM
  #23
KingsDodges
Originally Posted by Alfons
I'm assuming that the 9" reference is to the rim width, if so, this will comfortably handle a tire of around 11 - 12" width. I'm installing a 2" leveling kit and a 3" body lift and with my recent test fit, I can go with a tire diameter of anything under 33" will fit into the wheel well with some possible need to trim. This test fit was using a rim with an offset of 25mm (which is roughly 1" - an 18" offset would push the tire out by approximately 1/4" as compared to mine.). I'm looking at using a Nitto Terra Grappler 285/70-17
Is the 33" before or after the lifts?
Old Jun 2, 2012 | 10:54 AM
  #24
KingsDodges
Alright everybody...i bought new wheels
Now i need to know what size tires i can fit lol
i bought some 17x9 inche wheels all thanks to dakotaff!!
suggestions?
Old Jun 3, 2012 | 05:47 AM
  #25
italiandominator's Avatar
italiandominator
Here are the measurements of the wheels and tires that I got for my truck...I'll try to post pics again, my post got moved to the general discussion section and I think the pics got deleted, but the links might still be there
4 8X9 5-139 ET19 ULTA GOLIATH 234.00 EACH
4 LT265/65R18 BF AT TA KO RWL E 256.00 EACH
Old Jun 3, 2012 | 08:37 AM
  #26
dakotaff's Avatar
dakotaff
suggestions?
I would stick with 265/70/17, going with 285's could present problems.
