Brakes
Free Rotors! who wants 'em!?!
it is an easy job though...I lacked the elbow grease with the caliper bracket bolts so I took the end piece of the floor jack's lever and used that as a pipe to give myself the extra torque. Overall, easy as hell compared to a lot of the other vehicles I have worked on. Most important part of a brake job in my opinion is plenty of lube and using it in the right places. By right places I just mean don't get anything on contact areas such as outer surface of the disc and the lining of the pads. Brake work is fun in my opinion..and painting your calipers helps add to it!
Just changed the front pads on my 08, went with Wagner thermo quiet semi metallic and had the stock rotors turned. They work excellent and it cost me well under $100. The swap was very easy, the hardest part was getting the double piston caliper pushed back in but even that wasn't very difficult. The rotors came off mine super easy, a few even hits from the back with a rubber hammer while turning the rotors.
Did my wifes Expedition as well but used the Orielly Brake Best Premium pads and they are great brakes as well. No noise and smooth strong braking ability.
No need for drilled or slotted rotors unless your doing autocross or something.
Anybody know the life of the drum brake shoes on these trucks? That looks like a fun job.... not
As far as the rears, I am not sure but I hope it's more than 64000 miles haha.
Put Wagner Thermoquiet Ceramics on my wife's Durango's rear brakes when they needed replacing a month or two ago. They seem to work well, but squeak a bit when she brakes now. Not the ugly "replace me!" type squeak, but the "brand new brakes" type squeak, and only when she hits the pedal slowly. I may consider a different brand next time around, but it honestly could be her rotors need replacing after 85k miles.
