Front End Upgrade Time
Old May 3, 2012 | 10:45 PM
  #21
06Dak4.7Silver's Avatar
06Dak4.7Silver
(2) Monroe Part # TS58650 - Sensa Trac Load Adjusting
I think those are sold in pairs so if it says $210 then delete one because Rock Auto charges $105 for the pair as of this morning..for Rancho RS5000 they were sold individually thought.
Old May 4, 2012 | 08:22 PM
  #22
08XDakota's Avatar
08XDakota
Originally Posted by rebel4055
What about the lowers?
Should I do them? I only want to do them if I HAVE to lol already rackin up a big chunk s change
Old May 4, 2012 | 08:24 PM
  #23
08XDakota's Avatar
08XDakota
Yea I noticed I was just saying like 2 of them. Thanks for the check though!
Old May 4, 2012 | 08:50 PM
  #24
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by motodeficient
What is with these trucks? I got mine with 29K and by 38k I had replaced swaybar links, swaybar bushings, font and rear shocks, front brakes, tie rods, ball joint, control arms. Now its squeaking in the front again over bumps. I need to get rid of this thing ASAP.
If you use cheap parts, or even factory parts, thats what will happen sometimes. You need good parts.
Old May 5, 2012 | 12:26 PM
  #25
Deer Hunter's Avatar
Deer Hunter
Do lowers. 315.00(shipping included) from rock auto for uppers, lowers and stab links, all moog greasable. Took about 8 hrs in driveway( took my time and wire brushed and anti-siezed). Need a ball joint press to install lowers, knocked them out w 6 lb hammer in 4-6 shots each. When putting your knuckle back on, dont tighten upper arm and you wont have to wrestle with trying to squeeze uppers and lowers together to mount knuckle. After everything else is together and torqued, set a jack stand under the lug bolts(small piece of wood between to protect threads) and lower truck to bring upper arm to ride height and then tighten and torque upper arm bushings to frame.
Old May 5, 2012 | 12:29 PM
  #26
FrenicX's Avatar
FrenicX
Old May 5, 2012 | 01:39 PM
  #27
Zombifyd's Avatar
Zombifyd
Don't forget strut mounts... I ordered them just because they were cheap and might as well.
Old May 6, 2012 | 05:21 AM
  #28
Deer Hunter
You know thats right! On these front ends, if you can get to one thing because you have something else apart, and you can afford that other part, change it. Because you're gonna have to do it anyway.(and always sooner than you expected) These front ends are not hard to work on and only need a couple special tools. A ball joint press only to install lower bj, because its easier to knock it out with a 4 lb hammer in 4-6 shots than to try to press it out. (which you can also use to press in or out any bushings you might need to do) And that biga$$ 35 mm socket for the axle nut.
Old Oct 28, 2012 | 03:16 PM
  #29
08XDakota's Avatar
08XDakota
Finally ordered my struts! Now i just need to order the tie rod ends, upper control arms, and sway bar links. Hopefully it dosnt take me as long to order those lol
Old Oct 29, 2012 | 04:51 PM
  #30
Deer Hunter
Get your uppers and your lower ball joints, those can all be replaced while you do struts. All that stuff needs to be taken apart to replace struts anyway. Tie rod ends and stabilizer links can be done without having to take anything else apart to get to them.
