Idle problem
Old May 10, 2012 | 09:41 AM
ChaosAV's Avatar
ChaosAV
Unhappy Idle problem
I have a 2007 dakota slt,4.7 flex. When I start up cold (morning, after work) The idle pulsates up /down then will eventually settle and will run great. Only seems to happen on cold start up.
Any ideas?
Old May 11, 2012 | 01:46 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Replace your Throttle Position Sensor..
Old May 11, 2012 | 03:27 PM
I'd try cleaning out the throttle body and the sensors first. Then disconnect the battery and leave it disconnected for an hour or so. Cheaper that way.
Old May 11, 2012 | 05:24 PM
FrenicX's Avatar
FrenicX
Could be the Idle Air Control Valve too, I would try cleaning it all first as kent said, as between the two parts there it's like $100
