Plugs
Old May 10, 2012 | 03:47 PM
carlb87's Avatar
carlb87
Default Plugs
So I finaly changed my spark plugs. I put in nkg v powers. the ones recommended under the hood and a .040 gap which is also what the hood said. When I changed them I found out that is what I already had in there. But it was defenatly time to change them out. On a cold engine all of the old plugs were gapped at .056 - .060! Took the truck for a short drive and it feels peppier and more responsive. We will see if there is any mpg to be gained in a couple weeks.
Old May 10, 2012 | 05:09 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
great pictures brother..swapped out my Champions for these a couple months ago. I like them as well
Old May 10, 2012 | 07:14 PM
Reject's Avatar
Reject
Im running Autolite's First time ive replaced them, They are better then what they were smoothed out my idle. Mine are gapped to .35 I got a V6, Not sure if you have a V6 or V8. I couldnt even get my old ones out of the block myself.
Old May 10, 2012 | 07:43 PM
superdak05's Avatar
superdak05
running the autolite 3922 great plug and are 2 steps cooler then stock
Old May 10, 2012 | 07:59 PM
Eimer123's Avatar
Eimer123
Wow those old plugs are very clean! That is a very good sign!
Old May 10, 2012 | 08:54 PM
rebel4055's Avatar
rebel4055
My factory ones were that clean too. Wonder how these 3922s I have are managing. Maybe I should pull them out and check the gap.
Old May 10, 2012 | 10:25 PM
carlb87's Avatar
carlb87
Thanks. You see or feel any difrence with these?
Ya I have a v6 also I concidered going with the .035 with but decided to go with factory spec. for my perticular truck. Mine were in there preaty good but I got them out but since there were the v powers already I guess this is the secoind time they have been changed. I bought the truck with 54xxx, now at 60xxx
I had thought about doing that but im still under extended warrenty and decided to use the plug that was recommened for that reason just to be on the safe side
Old May 10, 2012 | 10:46 PM
Eimer123's Avatar
Eimer123
I would not switch to the 3922, your plugs you pulled look fine and match your trucks tuning just fine.
Old May 11, 2012 | 04:15 AM
rapta619's Avatar
rapta619
I just put e3 plugs into the truck. Man talk about a smooth idle. And the initial throttle response is incredible now. I just wanna see an extra 20 miles a tank. 220 just ain't far enough.
Old May 11, 2012 | 02:43 PM
superdak05's Avatar
superdak05
how do you only get 220 miles to a tank, I have the same 4.7, I still average close to 400 miles on a tank, 325 if i am out racing that weekend
