Tire Size Question?
Old Jun 3, 2012 | 03:50 AM
KingsDodges's Avatar
KingsDodges
wheel spacers work but the only problem i had with my last truck was the caused my tires wear unevenly and i have an issuse with one of my front wheels bcuz the spacer caused some much stress on the wheel that in year period (deployment) wen i got home it acutally cause my wheel to warp... but being these are Dakotas and not a 2500 Cummins it might be different not sure yet
Just a Thought
Originally Posted by bonecollector 3
Also, will wheel spacers reduce rub or make it worse?
Old Jun 3, 2012 | 03:58 AM
KingsDodges
Originally Posted by jkeaton
Stick with the 265's. I have the same size tire and a 2.5" kit and I rub on full lock.
How wide are your wheels?
Old Jun 3, 2012 | 08:32 AM
dakotaff's Avatar
dakotaff
I am ok with having to trim a little bit but I really dont want to have to hack up the entire wheel well...... The 265s will look beefy enough with the 2in lift?
265's will be a good size, no need for anything bigger.
I have read that 2in is the max that is safe to run on 4x4 but I see that you have a 2.5in kit.... Do you think I would be ok with the Rough Country 2.5in kit and 1.5in rear blocks?
It's a lot better for the front end going with a 2" kit. Also, the extra 1/2" won't allow for a bigger tire anyway, go with the 265/70/17's and you won't regret it.
Same size on my truck below.
Old Jun 3, 2012 | 08:51 AM
I see the problem being if you really work the front suspension. the cv joints will actually bind if the wheel droops too far. may do the same thing with a 2" kit, I'm not sure.
Old Jun 3, 2012 | 11:33 AM
bonecollector 3's Avatar
bonecollector 3
My wheels are stock 17"x8" aluminums.
I wont be doing any serious offroading with the truck, And I like the idea of the Rough Country kit........ I also like the daystar kit but the website says it wont work with Trucks produced after 3/09?
Old Jun 3, 2012 | 03:32 PM
bonecollector 3
I am really comtemplating weather to get the 2in kit or 2.5in kit lol
Old Jun 3, 2012 | 05:16 PM
Well, I have not had any leveling kit caused issues with mine, but like I said, mines a road queen. Parking lot speed bumps are about as radical as I get...lol...but, like Dakotaff said, you will never know the difference, nor I doubt you could visibly see a difference between 2 and 2.5" imo and it won't make any difference in the tire size you will be able to fit.
Old Jun 3, 2012 | 08:56 PM
bonecollector 3
Im thinking I may get the Rough country kit........ For the amount of offroading I do I dont think it will make a difference.
Old Jun 3, 2012 | 10:01 PM
dakotaff's Avatar
dakotaff
Check out this bargain.
Old Jun 3, 2012 | 10:03 PM
I am of the school of thought that the factory front end parts are going to eventually fail either way. I will replace everything with quality, greasable parts when they do.
