Hissing + Cruise Control Problems
Old Jun 26, 2012 | 03:13 PM
twain101's Avatar
twain101
Default Hissing + Cruise Control Problems
Hello all,
A while back I noticed a hissing that was coming from behind the glove box. Then I noticed that my cruise control was not changing gears (downshifting) and dad told me that it all works on the vacuum system. I decided to do some investigating and found that there is a connection running from the engine compartment to the cab (like an elbow joint of sorts), and when I pinch it the hissing stops. I don't have a picture of it right now, but could someone tell me the name of that part and if it is something I can replace? I'm a total novice when it comes to engine repairs but can get myself around with proper instructions.
Thanks for any help you can give.
Old Jun 26, 2012 | 05:12 PM
Can you provide since specifics on your truck? I think cruise is electronic on 3rd gens.
Old Jun 26, 2012 | 05:13 PM
twain101's Avatar
twain101
It's a 2005 Dodge Dakota
Old Jun 26, 2012 | 06:01 PM
Reject's Avatar
Reject
Cruise is Electronic on 06+ Daks, 05 is still a Servo, as the throttle is still a cable, not electronic to.
Old Jun 26, 2012 | 06:22 PM
novovictus1's Avatar
novovictus1
my 06 is cable as well, i added the servo from a junk yard to the tb. i think 08+ is drive by wire because thats when the TB mount changed on the manifolds.
Old Jun 26, 2012 | 09:10 PM
erau's Avatar
erau
Originally Posted by twain101
Hello all,
Per the service manual, on the 2005, the tube that elbows into the firewall is connected to a vacuum reservoir for the cruise control system. The reservoir is mounted on the bottom of the windshield wiper cowl, and can only be replaced, not repaired. There's also a check valve, but it's not clear the exact location on the line.
Old Jun 26, 2012 | 10:39 PM
Hmm...learn something new every day...lol
