The OFFICIAL Lift and Tire Size Thread
Old Apr 22, 2014 | 12:24 PM
  #151
donkeypunch's Avatar
donkeypunch
King Jackass
Barry, get out your recip. saw and start cutting....a lot. You will find that when the truck is on the ground and you turn the wheel...you will probably start ripping stuff off.
I have 285/75/16s (33x11.20ishx16s) and I have had to remove the entire mudflap, and close to 2" out of the pinch weld and fender. I have probably cut out 8" of the wheel well liner. I will post pics in a minute....stay tuned.
Old Apr 22, 2014 | 12:53 PM
  #152
donkeypunch
King Jackass
Here is a good example of what needs to come out of the fender after you remove the mud flap. Keep in mind, this photo shows the closest point the tire comes to the cut, at ride height. I actually need to trim about another 1/2" for clearance under compression.
In this one, you can see that I HAD to remove over 2" out of the pinch and whole sh*t load out of the wheel well liner.
Here you can see the wheels at full lock, at ride height. The tire still touches the wheel well liner at a little over half compression.
Hope this helps.
Old May 9, 2014 | 10:46 PM
  #153
Aim High 07's Avatar
Aim High 07
Default Lifted 2wd 07
3" leveling kit and 3" body lift. Ready for new meat. Will go as big as I can without trimming. Stay tuned
Old May 10, 2014 | 10:22 AM
  #154
Ronius_MAXimus's Avatar
Ronius_MAXimus
I feel like Spiderman.
Old May 10, 2014 | 02:28 PM
  #155
Mad042's Avatar
Mad042
I have a 2008 Ram 1500. I have 20" stock rims and want to put 17" rims on.
I was told that if a Ram comes with 20" stock rims that you can NOT do a smaller rim because of the brakes. is this true or will the 17" rims fit?
I currently have Bilstein leveling shocks (around 2 inches of lift) on the front and the rear is stock height. I an putting in a 2" suspension lift kit next week.
I would like to put on 17" rims with 35 X 12.50 x 17 tires. Will this work?
I am looking at Ultra type 164 It is a 17x9, 4.45 backspace, 5-139, with a -12mm offset.
If this will not work what should I be looking for that will get me close to this set up?
Thanks for any help you can provide.
Old May 10, 2014 | 03:02 PM
  #156
dakotaff's Avatar
dakotaff
You can absolutely mount 17s on a 2008 Ram 1500, even though it came with 20s. The brakes are the same whether it came with 17" or 20" wheels.
Post over in the 3rd Gen Ram section and they will help you out with offset and tire fitment.
Old May 10, 2014 | 03:43 PM
  #157
Mad042's Avatar
Mad042
Thank you.
Old May 13, 2014 | 08:52 PM
  #158
bmc586's Avatar
bmc586
Default 3 inch body lift
hey guys im a new member. I have an 07 Dakota Laramie and am looking to beef it up a bit. I am looking at the jack my ride leveling kit and 3 inch body lift. I have a friend that is a mechanic and I asked him what it would cost me to get this installed. he said it is a 12-14hr job n he will charge 40$ an hour instead of his normal 50$ rate. I am just wondering, those of you that have had this done...do you know how long it took and how much it cost you. Your input would be greatly appreciated. Thanks!
Old May 14, 2014 | 10:27 AM
  #159
donkeypunch
King Jackass
Depending on the style of the leveling kit, and the integrity of the components you are seperating, the leveling kit can take you anywhere from 45 min to 4 hours, generally. My leveling kit took 45 min to do both sides. Most members say the body lift is around 10 hours.
Old May 15, 2014 | 11:44 PM
  #160
gogetta628's Avatar
gogetta628
got my lift! 3 in bl and 2in leveling kit my buddy and I are gonna put it on on thursday any advice???
