Steering Shaft Problem
Was driving the truck around today. After I made a turn something happened and now the steering wheel binds when I make a turn. It's fine if i'm going straight but when i try to turn left or right it will bind then free up and turn normally, then bind again when i get back to straight. Kind of hard to explain, but it makes it hard to turn. I don't know what happened. I took a look at the steering shaft and it looks like the angle on the top U joint is to much and that's where its binding I think.
Here's some pics, if someone can point out anything that looks like its out of place let me know. I do have the shaft extension in from the PA body lift. But i never had a problem at all till today.
Top U joint
Bottom of the steering shaft.
Top U joint
Its just another junk part that Dodge had made for this truck.
You best bet is to replace it. The entire part is under $100 bucks and is held in by a pinch bolt on top and one on bottom. Just make sure to spray the crap out of those pinch bolts for several days before trying to remove them.
