Changing out the Reading/Map Lights?
Try tilting it down in the front before you slide it forward. I'm not sure of the exact procedure to get it out, but I didn't have any issue opening it up. The owners manual might have some information about it, there should be a section regarding changing bulbs. There is only the one screw, so you're going to have to shift it around a bit until it comes loose. Remember there are wires connecting it all, so don't try to force it.
oh well
