High Definition light Bulbs
Agreed it's HID, not HD but its no big deal. People call it that around me all the time and my geek/gearhead *** always corrects them that it is high intensity discharge. Anyways, pick up a low beam H13 w/ halogen high kit from either ddmtuning.com or hidextra.com...get yourself a relay harness which you will see as an option on both sites and you will be all set. if you have fogs (H10) I recommend changing those to HID's as well. For anything else, upgrade to LED's, not HID. HID's require ballasts to power them and even if you got slims I think it would be a pain to have to mount them everywhere and worry about any kind of electrical nightmare with your truck.
Do you guys know of any good DIY Youtube videos or anything on how to install HID's? I've been putting it off for a while, but a friend of mine wants to do it on his Jeep when I get home and figured we could both do it together.
Also, in reguards to doing HID's in your fog lights...I've heard before that you have to be careful doing that cuz the lenses on the fog lights could melt if you use a light that gets too hot...is that the case here and if so where would you go to get replacement lenses?
Trending Topics
it is rather easy, remove the headlight assembly (3 bolts and ball socket thingy), remove the headlight bulb, replace with new bulbs, zip tie ballasts to the frame one behind the drivers side and one behind the passenger side, connect the ballast to the bulb via the connector, now take the relay-> connect the one with the headlight socket to the drivers side factory light bulb socket-> take the long wire with the two plugs on it put one in the drivers ballast then run the other across to the passenger side-> i grounded this wire on each side with the factor ground bolts, theres one on each side of the frame-> now run the relay power wire to the battery.
I can get pictures if you so request.
in regard to the fog lights, the hid bulbs are 35 watts and the normal bulbs are 55w halogen, so they attually don't burn as hot as the stock bulbs. so your safe on that one
